So I have an R-code that was built in Metuchen in October. It has a few out of place items under the hood. Being an R-code it would come with the shaker scoop as standard equipment but this car also came with the hood scoop power lead wiring harness which ran out to the front turn signals. The hood scoop power lead harness is a separate harness from the main harness. It was never plugged in and the plug ends were taped to the main harness. Also it has two service stickers. One on the driver side tower which is normal but it also has one on the passengers side cowl. You can clearly see that the sticker was applied high enough that it was actually attached to the bottom of the rubber cowl seal. Just wondering if anyone else has seen any of these before? It is an original unrestored roller with 35K on the odometer. The drivetrain was removed in 1974 and the car sat outside in the weather from 1975-2003.
