Author Topic: Axel vent questions  (Read 864 times)
Axel vent questions
« on: April 27, 2021, 10:23:54 PM »
Does someone have a NOS axel vent hose that shows the clamp indexing band and the distance that band is from the axel end. The assembly manual shows a grommet used in the body. Were the grommets consistently used. I did not find one in this Metuchen car.
Re: Axel vent questions
« Reply #1 on: April 27, 2021, 10:48:51 PM »
The NOS one I opened is 15 3/4 to the middle of the yellow mark. Good luck trying to get the hose to fit in the grommet .
« Reply #2 on: April 28, 2021, 12:31:40 AM »
Perfect just what I needed!
LOL been there done that, lost the grommet in the body trying to push the hose through. Possibly why most cars do not have the grommet.
« Reply #3 on: April 28, 2021, 08:37:14 PM »
Sometimes I've been able to attach the hose and the grommet together before installing the grommet into the hole. - just getting it started - maybe a couple of inches inserted  as a start and a place keeper. Hose flexed enough to allow me to work the lip in the grommet in and around carefully with a somewhat thin nylon weather strip tool
« Reply #4 on: April 29, 2021, 08:51:24 AM »
Thanks for the help guys, mission accomplished.
« Reply #5 on: April 29, 2021, 11:43:35 AM »
I think the repro grommets are softer/more flexible than original too...
I've also pushed a couple through into the hole... not fun!
« Reply #6 on: April 29, 2021, 12:09:30 PM »
there is a trick to that. tie a piece if thin string around- thru the grommet. insert grommet in hole then remove string.
« Reply #7 on: April 29, 2021, 04:05:51 PM »
I've used a small, flat blade screwdriver to do the same function.
