Author Topic: 68 carpet cut off line  (Read 819 times)
« on: April 25, 2021, 10:43:48 PM »
Is the 68 carpet cut off line the same on a Metuchen car and a San Jose car above the pedals? My original carpet was missing on the Metuchen car and I have a unrestored San Jose car that has the original carpet.
Re: 68 carpet cut off line
« Reply #1 on: April 26, 2021, 01:41:58 AM »
Found a couple of different cars and pictures of the drivers side forward edge of carpet
Seem to match each other. Appear to be slightly different than what I've seen on 67 San Jose. Didn't take the time to look at 68 San Jose
Offline Coralsnake
« Reply #2 on: April 26, 2021, 08:53:24 AM »
A little hard to see but there are a series of notches along that edge for the pedals, each is a different shape
This is an often overlooked detail when replacing rugs.
« Reply #3 on: April 26, 2021, 09:46:21 PM »
Thanks for the replies. I will post a picture of the unrestored 68 HCS, San Jose assembly plant. It is not much different that the Metuchen photos. Most likely they were all slightly different.
Offline TLea
« Reply #4 on: April 26, 2021, 10:16:48 PM »
Your sj pics look a little cruder than I?m used to seeing on nj cars but that could be wear. Jeff?s pictures are typical plus the accelerator rod has cut about 2? long and 5/8? wide with radius bottom
« Reply #5 on: April 27, 2021, 06:46:20 AM »
Sticking to only Metuchen 68's,
Would this be consistent (same as) AUTO TRANS applications?
« Last Edit: April 27, 2021, 06:49:01 AM by 67gtasanjose »
« Reply #6 on: April 27, 2021, 05:25:49 PM »
Yes
