Author Topic: Power steering pulley detailing  (Read 1979 times)
« on: April 25, 2021, 10:38:47 PM »
I am working on power detailing a 68 steering pulley. I was told that very front surface that the puller would engage was left bare steel. I looked through all of my unrestored pumps and found paint on them. If the assembly plant makes a difference it came from Metuchen. If it matters it is a Ford Thompson pump.
Offline TLea
Re: Power steering pulley detailing
« Reply #1 on: April 26, 2021, 10:12:08 PM »
Marty, unrestored nj cars typically have front face bare steel. Even if pump has been repainted you will often see pitting on that surface and none on pulley
« Reply #2 on: April 26, 2021, 11:26:27 PM »
Big block and small block?
« Reply #3 on: April 27, 2021, 07:00:09 AM »
Without trying to hijack the thread, details like this would likely carry across many Ford model/option lines (as well as year-model coverage).
I wonder is a larger net might be cast on this detail.
« Reply #4 on: April 27, 2021, 12:54:57 PM »
The "application" can be verified by the use of Ford Car Parts (aka MPC), a copy of which is located in this Forum's Library section under each major topic.
« Reply #5 on: April 27, 2021, 03:29:46 PM »
No, I think you misunderstood me...not application as a part number or what all vehicles a particular pulley fits onto...
I was referring to the detail of the pulley having BARE STEEL on the "puller groove", or perhaps a better term, the hub of the pulley. Is this something found on other cars BESIDES just the O.P. 's application.
« Reply #6 on: April 27, 2021, 04:39:41 PM »
That is commonly known as "application", also known as "where used", as on other cars of the Ford lines. How you "apply" paint is another use for the word "application" (isn't English fun).
Now, to an "application" technique. I bead blasted almost all the pulleys used on my Mustangs, then paint them. Paint in the "groves" can cause belt slippage. Ford had a 3/8 to 1/2 inch wide rubber ring of appropriate pulley diameter that went in the grove as a painting mask. Now, where do you find a rubber ring on short notice? I used 1/2 inch wide masking tape to mack the grove, several wraps around, stuffing, twisting and covering out to about 1/8 inch of the edge of the ring, then painted. A couple of minutes of the car's engine running "softened" the painted edge, just like an original pulley would get.
« Reply #7 on: April 27, 2021, 05:29:00 PM »
Yes we have seen/found a similar practice on other applications and years but would not apply it to all without further detailed investigation.. So not "all" statement across the years at this point IMHO
Offline TLea
« Reply #8 on: April 27, 2021, 05:37:22 PM »
I can?t say unilaterally for all mustangs but since I am referring to this and I think Marty is as a Shelby application they use the same pump big block or small block so the answer would be yes
« Reply #9 on: April 27, 2021, 06:30:12 PM »
I apply a light coat of natural  paint or clear to the inside. Wipe away the sides with solvent rag.
Cut a bungee cord slightly smaller than the circumference and put it into the groove.
A metal "C" holds the ends of the bungee together.
Paint and then remove the bungee.
The natural paint or clear is so the deepest grooves don't get rusty.
« Last Edit: April 27, 2021, 06:36:12 PM by Bossbill »
Offline dkknab
« Reply #10 on: February 21, 2024, 10:06:09 PM »
Old thread that I just discovered.  Am I to understand that I should not have painted the groves on my fan pulley and crank pulley?
David Knab
289 2V, AT, PS
Nugget Gold Interior
« Reply #11 on: February 22, 2024, 12:05:40 AM »
Yup. Read my reply number 6. Ford "wrapped" what is best described as a very large rubber band in the grove as a mask, then painted the pulley. Upon removal, what do you get?
« Reply #12 on: February 22, 2024, 12:44:11 AM »
The question asked in this thread is whether or not the hub or puller groove is painted. I think we can all agree that the belt groove is unpainted.
« Reply #13 on: February 22, 2024, 11:31:15 AM »
I'm sure I answered in the affirmative, and also presented a practical "how to" example based on what Ford did.
Offline dkknab
« Reply #14 on: February 22, 2024, 11:58:39 AM »
Do MCA judges look negatively towards painted grooves?
How about the power steering pump pulley.  Mine appears to have some black paint in the groove.
David Knab
289 2V, AT, PS
