Author Topic: 1970 NJ Service Recommendation Decal / Location for Oct 69 Build  (Read 881 times)
Offline alanmac
 According to Dead Nuts On there are two different decals (early and late).  I am trying to figure out which one is correct for my build date.  DNO believes early was Aug - Sept.  My car was built on 10/7/69, so very close.  Also where should it be placed? There is one picture at DNO of a boss built at Metuchen with the decal located above to the left of the washer reservoir.   Does anyone have a Metuchen built car built around my date that  could verify which decal and the location placement?   Any info is appreciated.  Alan
« Last Edit: April 23, 2021, 04:35:19 PM by J_Speegle »
1970 Mustang Mach 1
351W Shaker Hood
Built at Metuchen
Build Date: October 7, 1969
0T1190xx
Re: 1970 NJ Service Recommendation Decal / Location for Oct 69 Build
« Reply #1 on: April 23, 2021, 05:50:29 PM »
Sorry difficult to make out in some cases or see the finer details but location is consistent based on the production period you identified.
Likely another dozen examples were the pictures were cut off so that you could not see the front inner fender panel but no sticker visible on the shock tower. Of course you can findyour fair share of them mounted there on "restored" cars
Closes to your car  - 0T1127xx built 10/8/69. Very poor picture but attached to the forward section of the inner fender panel
0T1021xx
0T1066xx
0T119xx
Best and clearest look at a fairly early car 0T114xxx
For some of the others that will be viewing this thread From other thread postings
0T 1200-132xx
Dec 69 examples
0T121xxx
Offline alanmac
« Reply #2 on: April 23, 2021, 06:23:03 PM »
Jeff; Wow, this is great.  Its is clear that the decal should be located on the drivers side near the washer reservoir.  It appears the early decal was used on a car 1 day after my build date.   Thanks, I really appreciate the feedback.  Alan
« Last Edit: April 23, 2021, 06:27:57 PM by alanmac »
1970 Mustang Mach 1
351W Shaker Hood
Built at Metuchen
0T1190xx
« Reply #3 on: April 24, 2021, 12:06:16 AM »
Glad we were able to provide evidence and reason for you to base your choices and restoration on.
Offline alanmac
« Reply #4 on: April 24, 2021, 12:52:08 PM »
Its great when you have a clear answer.
1970 Mustang Mach 1
351W Shaker Hood
Built at Metuchen
0T1190xx
