Author Topic: 67 coil spring perch restoration  (Read 774 times)
Offline 68 GT
« on: April 15, 2021, 01:54:55 PM »
I thought about reusing our coil spring perches from our 67 NJ coupe, 289. Don't have the perches in front of me right now, but I guess from the factory they did not come with rubber for the coil spring to set on? What about replacing the rubber bushings on them? Hard to do? Where do you purchase rebuild kits or bushings for them? Figured I'd soak them in EvapoRust to clean them up, I don't have a tumbler.
VIN 7T01C246XXX
Actual build date 5-11-67
VIN 8F01J208XXX
Actual build date 6-27-68
Re: 67 coil spring perch restoration
« Reply #1 on: April 15, 2021, 03:41:10 PM »
No. But NOS versions made in the 70s did along with other details not correct for your build.
NOS does not mean assembly line correct.
Quote
You have to build spacers so the metal doesn't collapse both in and out. The bent over tangs are difficult to replicate. They are painful to restore correctly, in my opinion.
Quote
Larry's T-birds used to have originals. Other vendors offer various versions, some more accurate than others.
There is more than one thread on this topic...
