The NJ 67 coupe we're restoring was built April of 67. Four wheel manual drum brakes. Will upgrade to power front disc brakes from Cockostang. Question is, where are you guys buying your pre-bent brake lines and clips from? I need to check with Dan to see what brake lines I'll still need to buy. I'm sure I will need to at least buy the one that runs down the transmission tunnel to the rear. I'll be running all new fuel lines as well, where are you guys buying pre-bent gas lines and clips from?
