Author Topic: Noise issue out of the Instrument Cluster 67  (Read 420 times)
Offline Ralf
« on: April 09, 2021, 08:14:35 AM »
I have a noise problem coming from the instrument cluster. It is a humming (whir) sound which also increases with increasing speed. At a standstill and while driving. Could the constant voltage regulator behind the instrument panel be the problem or something else? All instruments are working fine (temperatur, gas). Have a speedometer/trip odometer and a tachometer.
Great thx for your help.
Ralf
« Last Edit: April 09, 2021, 08:20:08 AM by Ralf »
Re: Noise issue out of the Instrument Cluster 67
« Reply #1 on: April 09, 2021, 09:18:04 AM »
I would guess it was the tachometer because it is turning even when stopped.
Offline Ralf
« Reply #2 on: April 09, 2021, 11:07:13 AM »
Hm, yes, possible. Any idea to solve it?
« Reply #3 on: April 09, 2021, 11:22:20 AM »
Jumper the leads from the underdash harness side and see if the noise disappears.  If so, you've isolated it to the tach.  If not, it is something else.
