Author Topic: 1970 Mach 1 dash  (Read 877 times)
Offline Hipo giddyup
1970 Mach 1 dash
« on: April 07, 2021, 11:01:02 AM »
We are starting to work on the dash of my son's 70' Mach which is already out of the car. I have noticed that the lower portion where the glove box hinge mounts has been hacked and the door will not shut properly. I also noticed a bad dent in the inner metal portion, to the right of the heater controls. That will be a tough fix... I will be looking for a replacement but I wanted to make sure that ALL dashes in 70' were the same and can be interchanged between a coupe, fastback, and convertible. His dash is a Non-AC dash so a replacement will be less $$. Will a typical 70' dash have the correct stampings, holes ,etc for a Mach? Such as the hole to mount the sport lamp switch, etc??
Offline cobrajet_carl
Re: 1970 Mach 1 dash
« Reply #1 on: April 07, 2021, 12:15:35 PM »
Yes, a 70 dash is the same for all models. The sport lamp switch for a mach also served as a place for the rear defroster switch in a coupe or the power top switch in a convertible.
Carl
70 and 71 Dearborn mach Is
« Reply #2 on: April 07, 2021, 12:31:12 PM »
Thank you!!
« Reply #3 on: April 07, 2021, 05:15:52 PM »
I think that some might have the extra hole below wiper switch and lighter for the E-brake warning light option.
« Reply #4 on: April 08, 2021, 11:34:40 AM »
Good point, thanks.!
I am seeing that a good used dash assembly is around $100-$150 for non-AC? Does this seem correct?
« Reply #5 on: April 08, 2021, 11:45:52 AM »
Or two holes if Deluxe Belts, Tach and Parking Brake Warning light.
Carl
