Author Topic: c6 speedometer gear  (Read 1018 times)
Offline truetriplex
c6 speedometer gear
« on: March 30, 2021, 12:03:09 PM »
My car keeps eating the nylon speedometer gear in the transmission.  about every two years, the teeth end up becoming chewed off and I have to replace the gear.  I can seem to determine what could be causing this.  any suggestions
Offline Mike_B_SVT
Re: c6 speedometer gear
« Reply #1 on: March 30, 2021, 12:54:32 PM »
Have you replaced the speedometer cable yet?  It could be dragging and causing excessive wear on the nylon gears.
Mike B.
1 of 354 in Sonic Blue
Cat Bites Man!
Offline Coralsnake
« Reply #2 on: March 30, 2021, 01:11:27 PM »
Are you using the correct gear? The entire gear should be a solid color.
Some gears spiral different directions
« Last Edit: March 30, 2021, 02:28:30 PM by Coralsnake »
« Reply #3 on: March 30, 2021, 05:15:57 PM »
+1. I don't know what two years represents in miles but if lasting means a thousands miles before the gear gets chewed up at least that indicates a correct type gear. A incorrect gear would go away very quickly and not register correctly on the speedometer end.
« Last Edit: March 30, 2021, 07:52:30 PM by Bob Gaines »
Offline Coralsnake
« Reply #4 on: March 30, 2021, 07:46:50 PM »
And since Mr Gaines is always correct, make sure the cable is not touching the exhaust pipe.
Offline jmlay
« Reply #5 on: April 14, 2021, 10:40:19 PM »
The retainer clip is installed, correct?
Mike
1969 Mach1 428 CJ Ram Air
San Jose
Scheduled Build: 1/2/1969
Actual Build: 1/3/1969
Released: 1/8/1969
