Author Topic: Upper A Arm markings?  (Read 3529 times)
« on: March 23, 2021, 10:50:42 AM »
I see a cartouche that is like a triangle with a D inside, and C6. I am suspecting the C6 is a date code maybe? Both arms were marked exactly the same.
Re: Upper A Arm markings?
« Reply #1 on: March 23, 2021, 07:13:58 PM »
Have seen and have pictures of early version stamped there but have others stamps at the outer surface of the ball joint cover area like the later cars.
Only seen a few with that makers marking - rounded triangle with the D
« Reply #2 on: March 23, 2021, 09:10:20 PM »
These came off my February '68 GT-E. Rebuilding them for the second time. Last time was 25 years ago. Best I can tell they are original to the car. Both identical.
« Reply #3 on: March 23, 2021, 09:26:44 PM »
Any stamping out at the outside surface of the ball joint cover area?
Two versions I've got pictures of have C6 and C4 stamped in the same location where you found yours
Offline 69bossnut
    • DSD Restorations LLC
« Reply #4 on: March 23, 2021, 10:17:38 PM »
I believe the triangle with the D is the stampers logo or mark. I always guessed the C6 had something to do with the engineering number. Have seen many 67-69 style arms with those markings. I believe the cut back version has a different maybe C8 but can?t remember for sure. Have seen several stampings out on the outside area of the ball joint hump which is a date stamp. But not all have them from what I have seen.
DAVID DAVIS
DSD RESTORATIONS LLC
5075 E. COUNTY RD. 126
BLYTHEVILLE, AR. 72315
870-780-4999
dsdresto@gmail.com
www.dsdrestoration.com
« Reply #5 on: March 23, 2021, 10:24:25 PM »
No other marks that I can see.
« Reply #6 on: March 23, 2021, 10:26:26 PM »
I have another car I am restoring that was built in June 1968. Will see if it has any markings.
« Reply #7 on: March 24, 2021, 04:23:55 PM »
Agreed
Or since these were provided by an outside vendor at least a method of identifying them from others
I have them spanning from 64 through 69 at this point. Maybe another different vendor - different practice thing
Thanks for participating David
« Reply #8 on: March 24, 2021, 05:47:07 PM »
Looked at the pair from June 15 Dearborn car. It has cut back style A - arms. No markings on either one - and they are not cracked.
« Reply #9 on: March 24, 2021, 07:26:23 PM »
Since I didn't see a year in the title, several of my 64-66 Upper A Arms are stamped with a triangle and "C4" on the underside, to the front if it was installed on the left side.
« Reply #10 on: March 24, 2021, 08:35:43 PM »
The year and car is in my signature.
