Author Topic: Wire Harness Retainer clips  (Read 955 times)
Offline alanmac
« on: March 20, 2021, 07:57:19 PM »
Hi I am missing the round retainer clip Item #8 on page 5 (drawing E0-115-1) of the Jim Osborn electrical assembly manual.  The (2) clips are mounted in holes located in front of the right shock tower and below the regulator.  The manual lists three part numbers.  383207-s, 38477-s, 383104-s.  Which part number is correct?  Does anyone reproduce these?  Alan
1970 Mustang Mach 1
351W Shaker Hood
Built at Metuchen
Build Date: October 7, 1969
0T1190xx
Offline tim_morrison82
    • Click Here for My Project
Re: Wire Harness Retainer clips
« Reply #1 on: March 20, 2021, 11:07:26 PM »
« Last Edit: March 20, 2021, 11:14:50 PM by tim_morrison82 »
« Reply #2 on: March 21, 2021, 12:36:28 AM »
Part number 383104-S is item 9, and does not apply. Your part number 38477-s is written 383477-S and is the standard clip with a wire capacity of 0.62 inch.
Part number 373207-S is for a "Regular Production Option" (R. P. O.) with a wire capacity of 1.0 inch.
There are actually 4, two additional clips are on the underside of the right hand shock tower to firewall brace as item 8. Match them to the dimensions listed above.
Offline alanmac
« Reply #3 on: March 21, 2021, 01:27:57 PM »
Thanks for the feedback.  I have the 1" retainers.  I am looking for (2) of the .62 diameter retainers.  I believe its reproduced as AMK F-417.  Now I can't find a seller.   Alan
1970 Mustang Mach 1
351W Shaker Hood
Built at Metuchen
0T1190xx
« Reply #4 on: March 21, 2021, 02:20:19 PM »
All four are the same. You apparently have the assembly manual, it's time to review it.
In any case, both types are available from AMK. Use the Ford Part Number on the AMK website to get the AMK stock number.
Offline alanmac
« Reply #5 on: March 21, 2021, 04:35:43 PM »
I don't need the two retaining clips under the shock tower support.  I just need the two as mentioned.  I used 383207-S since I had them.  Thanks for the feedback.
« Last Edit: March 21, 2021, 09:04:25 PM by alanmac »
1970 Mustang Mach 1
351W Shaker Hood
Built at Metuchen
0T1190xx
