Author Topic: 1967 Mustang Fastback GTA 1/4 Vents  (Read 1234 times)
Offline Anghelrestorations
    • Anghel Restorations
« on: March 13, 2021, 03:52:39 PM »
Just wanted to confirm here on a 1967 Mustang, like in the photos here, what others have seen.  Would all the pieces of the vent be body color or is the inside of the vents black based on original cars?
2021-03-10_15-14-20 by Marcus Anghel, on Flickr
20210312_091201 by Marcus Anghel, on Flickr
20210308_152622 by Marcus Anghel, on Flickr
« Last Edit: March 15, 2021, 03:52:57 PM by J_Speegle »
Marcus Anghel
www.anghelrestorations.com
Re: 1967 Mustang GTA 1/4 Vents
« Reply #1 on: March 13, 2021, 03:59:28 PM »
« Reply #2 on: March 13, 2021, 07:00:20 PM »
From your second posted picture the one panel appears to be semi-gloss black with evidence of a repaint over it. The thin steel panel is the questionable one
Will merge both topics in a day or so to keep them all together
« Reply #3 on: March 13, 2021, 10:49:32 PM »
Thanks for the comments and link to the previous thread.  I have a few more of these vents at my shop that I will take apart and look at but from what I see I think I agree body color is probably correct for everything you see from outside of the car.  The piece seen from inside the car is black.  Would make most sense as well.
Marcus Anghel
Offline Shawn
« Reply #4 on: March 15, 2021, 08:45:36 AM »
I've taken apart quite a few of these from their original state.  All were body color except for the interior most panel was black.
« Reply #5 on: March 15, 2021, 11:38:41 AM »
This weekend I was able to take a few more apart and can confirm that these were definitely painted body color.  So that means the outside trim piece and the screen.  The inside piece is black plastic.  And while at it the screws holding it all together are zinc dichromate from what I see here as well.  Mystery solved for now.
The white overspray you see is from when the car was repainted from green to white.
20210314_143825 by Marcus Anghel, on Flickr
20210314_144149 by Marcus Anghel, on Flickr
20210314_144156 by Marcus Anghel, on Flickr
20210314_144434 by Marcus Anghel, on Flickr
Marcus Anghel
« Reply #6 on: March 15, 2021, 12:15:43 PM »
For the inside piece there was a change from pot metal to plastic, but I don't know the date.  My Dec 66 SJ car has pot metal.
« Reply #7 on: March 15, 2021, 01:13:28 PM »
Yet ANOTHER running change?  ::)
« Reply #8 on: March 15, 2021, 01:58:25 PM »
I have a spare part (unknown if 67 or 68) that have the C7 cast numbers with plastic innards.
It's interesting that the thread size is cast into them.
See also part number and vendor.
No cast date found.
« Reply #9 on: March 15, 2021, 02:20:50 PM »
This car here I am working on and posted photos here is built mid November 1966 and is plastic and these are the original pieces.
Marcus Anghel
Offline K-HESS
« Reply #10 on: March 15, 2021, 03:23:27 PM »
The one on the left is cast and the one on the right is plastic. The cast one has a FOMOCO logo. It also has additional cast bars in 4 of the ribs while the plastic one has none. I also notice the cast one has a wider gap at the one end then the plastic one which is much closer. The weight difference is huge with the cast one weighing in at 1.4 lbs and the plastic one weighing in at just .4 lbs. Most of the cars here in upstate NY are from Metuchen with some Dearborn cars thrown into the mix. I have a box of these louvers and have both cast and plastic backings.
Re: 1967 Mustang Fastback GTA 1/4 Vents
« Reply #11 on: March 16, 2021, 10:46:32 PM »
Thanks for posting the photos...thats great information.  Haven't studied these close enough to realize there was two versions, but now we know.  I would tend to agree the early versions would be cast and then the plastic ones were made as they probably were cheaper to produce as well.
Marcus Anghel
