Author Topic: 67 Disc Brake Pad Retainer Finish  (Read 1681 times)
« on: February 07, 2011, 09:40:13 PM »
OK - can't remember this moment :(
Correct finish for the brake pad retainers (disc brakes) on an approx Nov 66 built 67 San Jose Mustang/Shelby
Re: 67 Disc Brake Pad Retainer Finish
« Reply #1 on: February 08, 2011, 01:35:04 AM »
I have seen some that were apparently bare steel on the smaller 67 style retainers and others that appeared to have been zinc phosphated. Bob
« Reply #2 on: February 08, 2011, 09:29:58 PM »
Thanks Bob -  I've got choices  :-\
« Reply #3 on: May 07, 2020, 11:25:50 PM »
Yeah, it's been quite a while since this was posted.
Have we learned anything different? Bullett68s query regarding 68s and my current cleanup of my 67 SJ K/H calipers has me asking.
« Reply #4 on: May 08, 2020, 12:46:30 AM »
Other then I am leaning more toward phosphate and oil upon reflection. Given other retaining hardware of the same function are finished that way and if they were bare steel in that exposed location they would be more apt to rust away . There are enough examples to conclude that was not always the case so the PO is most likely IMO.
« Reply #5 on: May 08, 2020, 06:05:13 AM »
So when was the split from early design caliper (early design retainers) to the 2nd design caliper with 2 retainers each side?
My 11/02/66 built has the original calipers still and are the early design, like a 65 or 66 Mustang type.
« Last Edit: May 08, 2020, 06:44:59 PM by 67gtasanjose »
« Reply #6 on: May 08, 2020, 12:21:59 PM »
My guess is late NOV/66 or early DEC/66.
« Reply #7 on: May 08, 2020, 12:24:17 PM »
And probably the same time hose fitting size and hardware changed too.
« Reply #8 on: May 08, 2020, 02:11:46 PM »
Ok, PO it is! Thanks, Bob.
I've also updated this post:
http://www.concoursmustang.com/forum/index.php?topic=13837.msg139939#msg139939
« Reply #9 on: May 08, 2020, 06:47:13 PM »
Bump...
I edited my ealier question to add context of Jeff's very old question that began this thread.
