Author Topic: Corrosion Removal  (Read 1404 times)
Corrosion Removal
« on: February 21, 2021, 01:28:50 PM »
Is there a product or method that will remove the black stuff from the shield with out damage to the original finish ?  Thanks, Brian
Offline Coralsnake
Re: Corrosion Removal
« Reply #1 on: February 21, 2021, 04:18:16 PM »
There was not finish on that part, it was bare steel. You can neutralize the corrosion, but it will likely return
« Reply #2 on: February 21, 2021, 04:23:38 PM »
Brian is that surface pitted also?  If so your better off just replacing with one that does not have the damage IMHO
« Reply #3 on: February 21, 2021, 05:03:38 PM »
interesting.  I've seen this black stuff before.  Usually a part of the general rust/corrosion package.  It's a surface situation that can be chipped/scraped off with a utility knife.  I have heard and read that ' bare steel ' is the usual and was a bit surprised at the appearance of this shield.  I had not though of replacing.  I didn't know that was an option ?  This shield may have been a replacement ?  Part is new to me and is for a C5AW-C Daytona pinion support.  It does have a yellow dab on the side.  Thanks for the help.
Offline preaction
« Reply #4 on: February 21, 2021, 05:10:24 PM »
Mabye evap o rust for a short time enough to remove the  " color " then Boeshield.
« Reply #5 on: February 22, 2021, 12:30:48 PM »
OK a bit more cleaning.  Appears to be all steel.  Thanks, Brian
« Last Edit: February 22, 2021, 12:33:00 PM by Brian Conway »
Offline Coralsnake
« Reply #6 on: February 22, 2021, 07:25:12 PM »
Very nice now
« Reply #7 on: February 22, 2021, 07:40:39 PM »
Much improved. Of course if the light pitting makes a difference a swap is possible as mentioned. Just have to get a better one
« Reply #8 on: February 22, 2021, 07:49:51 PM »
The stamped steel shield is simply pressed on. You can find a better one from a cheaper application and swap that part easily.
Offline 69bossnut
    • DSD Restorations LLC
« Reply #9 on: February 27, 2021, 03:17:11 PM »
The shield was serviced. I have bought a few over the years but don?t remember the part number.
DAVID DAVIS
DSD RESTORATIONS LLC
5075 E. COUNTY RD. 126
BLYTHEVILLE, AR. 72315
870-780-4999
dsdresto@gmail.com
www.dsdrestoration.com
