Author Topic: 66 K Code 4 Speed Driveshaft Markings  (Read 701 times)
Offline 1966KGT
« on: February 17, 2021, 11:36:58 AM »
I have an SJ, 11/08/65 K GT, 4 speed and was wondering what striping should be on mine, think it may have been re-tubed at one time as I find no striped but found paint marks on yoke, also no weights.
Re: 66 K Code 4 Speed Driveshaft Markings
« Reply #1 on: February 17, 2021, 03:23:06 PM »
Might end up merging this thread with one of the others on the subject
Guess you found other threads on the subject and they didn't help. Kind of got off topic a bit
http://www.concoursmustang.com/forum/index.php?topic=10965.0
Best guess from me at this point in time for your car would likely be
Front to rear in order
Light blue - Med Blue - Black Some have been found and described the black as a very dark green for this last stripe so don't know for sure what was going on
Have different combinations from other periods of time during 66 production just like 65
Tube may or may not have had the stenciled tube identification number. Only one out of three would have that marking
Offline 1966KGT
« Reply #2 on: February 17, 2021, 03:33:43 PM »
Thanks Jeff, would you know where a man could find original style weights as mine has none, so when I have it rebalanced if I need them, I have a local shop with high speed balancing capabilities. Were they different, rectangular, round, square or all of the above? I am at work and will research more tonight.
« Reply #3 on: February 17, 2021, 04:05:30 PM »
Some 66 examples that I've typically have found on original drivelines
Not sure of a source the company that balances yours may have these available, guess you could make them then remove a little from the side to get the right weight or try and remove them from a donor driveline then adjust and dress the edges to get the right balance. Shop is likely not going to be real happy with you and all your extra "needs"  :)
