Author Topic: 69 MACH 1 390 Dress Up Kit Identification  (Read 3508 times)
Offline STAUBY38
« on: February 16, 2021, 04:15:26 PM »
I have read that the Marti report denotes if the car had the chrome dress up kit on it or not however I am not sure what heading in the Marti would cover that.  Any ideas?  When I pulled this car from its long sleep in a garage from 1984 to present, I found chrome correct dated valve covers but a blue original looking air cleaner complete with correct 390 sticker on it.  Not sure which was original to this car and which was not.  Trying to get all correct items for a 390 isn't easy!
« Last Edit: February 24, 2021, 05:48:24 PM by J_Speegle »
1969 MACH 1 390 4 SPD
SAN JOSE BUILD 3-28-69
ACAPULCO BLUE BEAUTY
1969 MACH 1 351 AUTO
SAN JOSE BUILD 4-17-69
BLACK JADE
2013 BOSS 302
RACE RED
Re: 69 MACH 1 390 DRESS UP KIT IDENTIFICATION
« Reply #1 on: February 16, 2021, 05:13:49 PM »
1969 S code dress-up option is an interesting one. can't think of another time where buyers had this option that was installed at the factory. Could create a rabbit hole for the discussion if we try and figure out if the engines arrived at the car plant with the chrome parts attached to the engine (not referring to the air cleaner and breather). If so then was the engine ID tag or label different? Like I said rabbit hole :)
Did look at my pictures of unrestored cars and I found it interesting that on Dearborn S codes with the dress up options (valve covers and breather visible) the air cleaner lids with painted while on NJ cars the air cleaner lid was chrome. Not allot of examples but consistent
No good examples of unrestored San Jose examples only a few restored ones
Offline STAUBY38
« Reply #2 on: February 16, 2021, 05:25:05 PM »
That's very interesting because mine has chrome valve covers but a painted air cleaner including lid.  HUH   Maybe it came that way??   Do you know where I can obtain pics of unrestored San Jose 390 Mach 1 cars?   So many little things to get right when putting it all back together.  Original pics especially engine compartment would certainly help!
BLACK JADE
2013 BOSS 302
RACE RED
« Reply #3 on: February 16, 2021, 05:31:10 PM »
Not going to be allot of unrestored 69 San Jose S codes available. Good thing is that many of the 428 details are the same or similar just have to double check those. Things like the Thermactor system (minus may be the pump pulley) and the like. The rest of the engine compartment will be the same as any other Mustang built around the same time at San Jose. You might want to look at some of the
Currently there are two unrestored San Jose examples in the Unrestored Picture Thread section of the site that should help. Maybe I can find one or two more to add to the group. Won't be an S code though :(
Offline STAUBY38
« Reply #4 on: February 16, 2021, 05:35:15 PM »
Appreciate it!
BLACK JADE
2013 BOSS 302
RACE RED
« Reply #5 on: February 16, 2021, 09:18:37 PM »
Thermactor system was not used on the S code 390 in 1969 Jeff. It's an IMCO engine, the 1969 390-4V IP has a one year only intake manifold and a one year only 470 CFM Autolite carburator.
« Reply #6 on: February 16, 2021, 10:47:02 PM »
Thanks Royce - corrected above and forgot for the moment.
Think the one set of pictures of the restored car with Thermactor stuck in my head for some reason::)  Just one of the reasons I normally don't collect those
Offline STAUBY38
« Reply #7 on: February 17, 2021, 08:35:50 PM »
Royce/ Jeff,    Did the 69 390 come with the 4300 Autolite or another Carb?   I have what I believe is the correct intake   Do you know the casting # for the correct one?   I heard there were 2  One ended in A and the other B  ??
BLACK JADE
2013 BOSS 302
RACE RED
« Reply #8 on: February 17, 2021, 09:29:19 PM »
4300 Autolite.
Books say
C9ZF-E for manual transmissions   C9ZE-F for automatic cars
Edit note: Corrected the prefix on each  ::)
« Last Edit: February 18, 2021, 04:57:34 PM by J_Speegle »
Offline STAUBY38
« Reply #9 on: February 18, 2021, 08:21:47 PM »
My Autolite tag is missing   The only numbers I see on the base are C7DF  D    Not sure if this is a 4300 and if its correct for this car?
BLACK JADE
2013 BOSS 302
RACE RED
Offline STAUBY38
« Reply #10 on: February 18, 2021, 08:37:57 PM »
Looks like that part number may be a 67-68 289   HUH  Definitely not for a 69 390 ????
BLACK JADE
2013 BOSS 302
RACE RED
« Reply #11 on: February 19, 2021, 08:28:47 PM »
That one is easy - No its not correct for your car.
Here is what you want (specific number will be determined by your transmission)
Offline STAUBY38
« Reply #12 on: February 21, 2021, 11:30:46 AM »
Ok great.  Now just have to locate the right one   Thanks !
BLACK JADE
2013 BOSS 302
RACE RED
Offline STAUBY38
« Reply #13 on: February 22, 2021, 10:21:18 PM »
Did the dress up kit include a chrome oil filler cap also?
BLACK JADE
2013 BOSS 302
RACE RED
« Reply #14 on: February 23, 2021, 01:56:51 PM »
Your 1969 390-4V IP would have blue painted valve covers, a black oil cap, and blue painted air cleaner lid originally. If it was equipped originally with the chrome dress up kit option it would say that in the options list on the Marti Report.
The Master Parts Catalog gives a description of the items included with the Engine compartment chrome dress up kit.
I would start with getting the Marti Report unless you are just wanting to see chrome under the hood.
