Author Topic: Under Dash Wire Identification  (Read 1834 times)
Offline 1970 Snake
« on: February 05, 2021, 01:53:27 PM »
Can anyone advise what this under dash wire is for (circled in pic), what it connects to and where the clip attaches to the dash? It was not connected to anything when I disassembled my car.
Dearborn Built Sept 4, 1969
1970 Mach1 428 CJ R-Code C6
dash tach, front bumperettes
Re: Under Dash Wire Identification
« Reply #1 on: February 05, 2021, 04:30:34 PM »
Did you look in the 1970 Mustang Electrical Assembly Manual? Your picture shows a blue wire with a red tracer that goes to a two pin rubber connector with the blue-red wire "protected" by a portion of the connector; and a black wire "exposed" in the connector. The "protected" wires in connectors used by Ford are usually hot, 12VDC; the black "exposed" wires are usually grounds. Ford usually keeps the same color codes for all years (my 1999 E250 has many of the same color coded wires). The wiring diagrams in the Assembly Manual shows a blue-red wire used in the light dimmer circuit and identified as "wire 19 (A, B, C, etc)". I found one that fits the blue-red and black in a common connector. It's for the ash tray illumination circuit.
There may be more.
« Reply #2 on: February 05, 2021, 05:43:26 PM »
To start the detective process you have a plug with a ground and a wire connected to the dash lights it appears to me. Without getting out a wire diagram do you have the radio light already attached to the radio. First first guess given the wires and location
Offline 1970 Snake
« Reply #3 on: February 05, 2021, 05:57:37 PM »
Thanks for the info guys, this picture is from my disassembly file and considering your responses, it now makes sense that this is probably the AT shifter light connection and the clip goes on the front of the console. I will do some reviewing of the manual as suggested to see what this actually is for, there are a number of diagrams so need to ensure I review the correct one. Thanks again.
Offline 1970 Snake
« Reply #4 on: February 05, 2021, 06:13:44 PM »
my mistake, you are correct the wire is for the ash tray light and my console even has a faint marking on the underside where the clip was attached. My shifter light is attached by the wire running under the tranny hump floor pan to the outside of the fire wall and connects to the main harness there. Thanks again.
Offline 1970 Snake
« Reply #5 on: February 07, 2021, 06:52:08 PM »
I am looking for an under dash 12V power wire, can anyone advise what the square plug green wire is for, which I have circled in the attached picture, thanks
Offline Coralsnake
« Reply #6 on: February 07, 2021, 07:34:33 PM »
AC I believe
Offline cobrajet_carl
« Reply #7 on: February 07, 2021, 09:15:22 PM »
Think it's for the evaporator de-icing sensor.
Carl
70 and 71 Dearborn mach Is
« Reply #8 on: February 07, 2021, 09:42:41 PM »
AC I believe
No believing; it is for the AC system: either the AC switch or de-icer.
Offline 1970 Snake
« Reply #9 on: February 08, 2021, 03:51:27 AM »
Thanks guys, my dash is still out of the car and what I was hoping for, is if someone could tell me if it does provide a 12V source which I can use for another accessory, as my car will not have an AC system.
« Last Edit: February 08, 2021, 03:53:52 AM by 1970 Snake »
Offline DougDyar
« Reply #10 on: February 08, 2021, 09:25:37 AM »
You might look at the fuse panel. Some cars have an auxiliary power connection there consisting of a brass strip type fuse holder thingy. I don't know the correct term, but a pic of your fuse block would help to know if your car has this...
Doug
0F02G203277
« Reply #11 on: February 08, 2021, 10:15:29 AM »
No it does not.
« Reply #12 on: February 08, 2021, 12:56:55 PM »
There are several options for power that really depend on your use. Do you want a "constant on" circuit? Do you want a power circuit controlled by the ignition switch? I have a basic rule I follow - don't cut any wires.
Offline 1970 Snake
« Reply #13 on: February 08, 2021, 01:15:26 PM »
I need a power source for my roll control switch and would assume this wire would supply that. There are two wires like this in that area the is another identical wire there with the same plug but it comes off the heater switch plug and assume it goes through the heater switch first, so is not a source unless the heater/AC is turned on. BTW I agree I do not like cutting wires, which is why this wire interest me as a fused source always on in the right location.
« Reply #14 on: February 08, 2021, 02:03:07 PM »
I think that it plugs into the fan switch resistor. Also, should be one more wire with plug like that.
