Author Topic: Center console camera case finish paint  (Read 2032 times)
Offline Bluepony
« on: January 27, 2021, 02:23:55 PM »
I’m in the process of restoring the center console from my 68 convertible and need some recommendations on what type of paint to use for the center insert which has a camera case finish. Should it be satin black or I was reading another post recommending VHT wrinkle paint. Or should it be something else? I attached a picture of the center cushion and insert.
Craig Stambaugh
'68 Convertible J-Code Brittany Blue
'64 1/2 Coupe F-Code Silversmoke Gray
Re: Center console camera case finish paint
« Reply #1 on: January 27, 2021, 04:43:06 PM »
It would have been a version of semi gloss black. No need for a wrinkle paint since the surface had a texture that they would have wanted to be visible on the final product
Offline Bluepony
« Reply #2 on: January 27, 2021, 06:14:43 PM »
Thanks Jeff. I was pretty sure that was the answer. Thanks for the quick response.
Craig Stambaugh
« Reply #3 on: January 27, 2021, 07:40:11 PM »
I'd prefer more to the satin side.  Most interior bits were intentionally dulled down starting in '68.
Offline Bluepony
« Reply #4 on: January 27, 2021, 09:10:03 PM »
Thanks Charles.  I guess I was under the impression that semi-gloss and satin were pretty much the same, but actually I was panning on using satin black.
Craig Stambaugh
« Reply #5 on: January 28, 2021, 06:16:58 PM »
+1 Should have included that :(
Offline Bluepony
« Reply #6 on: February 12, 2021, 01:03:10 PM »
Thanks for the help on this. Used the satin black and it came out looking great. I have a bit of pitting in the chrome, so I may replace the insert some time in the future but I?m very pleased with the result.
Craig
Craig Stambaugh
« Reply #7 on: February 12, 2021, 01:38:04 PM »
It looks nice.
Do you have the inserts for the seat belt pockets?
Offline Bluepony
« Reply #8 on: February 12, 2021, 06:46:36 PM »
Yes I do. Just didn?t have them in place for the picture.
Craig Stambaugh
« Reply #9 on: February 12, 2021, 09:07:30 PM »
Good they are not easy to find.
« Reply #10 on: February 12, 2021, 10:30:20 PM »
No one reproducing them?  Thought that would have been something one of the places would have
« Reply #11 on: February 13, 2021, 12:47:14 AM »
I could be wrong but I do not think they have been reproduced.
Offline DragPack69
« Reply #12 on: February 15, 2021, 09:59:31 AM »
may I ask which paint you used?
I`m getting mine ready also.
I have an extra set of the inserts nif anyone needs a set.
They are not reproduced
Offline Bluepony
« Reply #13 on: February 15, 2021, 10:45:04 AM »
Sure.  I used Rust-oleum automotive primer and satin black enamel.  It lays down nicely.
Craig Stambaugh
« Reply #14 on: February 15, 2021, 04:10:47 PM »
Not sure that I would have used primer for this application - too easy to fill but surely reduced the affect of the grain somewhat at least. Factory just laid on a coat of the black but hope your choices met your expectations. Just a note for those considering the process in the future
