Author Topic: 64 1/2 Positive Battery Cable Changeover  (Read 957 times)
Offline FXguy
    • Early 64 June K Convertible Restoration
« on: January 21, 2021, 02:50:50 PM »
The 64 1/2 Electrical Assembly Manual shows that there was a revision to the factory installed battery cable from C4ZF-14300-B to C4ZF-14300-C on 4/18/64.  I have a C4ZF-14300-B, but I have been unable to find even a picture of a C4ZF-14300-C.  Curious if someone has a pic of one they could post here.
TIA
-Scott
« Last Edit: January 21, 2021, 05:29:12 PM by FXguy »
Scott McMullen
64 1/2 K Code Specialist, pre/early production historian, collector, and restorer.
"I'm absolutely sure of one thing, and that is I don't know everything...there is always something new to be discovered...and that's where the fun is."
Offline FXguy
Re: 64 1/2 Positive Battery Cable Changeover
« Reply #1 on: January 21, 2021, 05:30:09 PM »
I fixed the typo above.  I am looking for a  picture of a C4ZF-14300-C.
Scott McMullen
Offline midnite cruiser
  • midnite cruiser
« Reply #2 on: February 18, 2021, 01:00:18 PM »
Can't verify if this is the exact cable. But I have reason to believe it is original. Others please comment
JWhite
64.5 D code convert. / C4 / AC / PS / RP
« Reply #3 on: February 18, 2021, 01:07:30 PM »
It looks too thick of gauge of wire and the terminal end opposite the battery end covering is wrong. Evidence points to most everything else in the picture to have been altered so it would be no surprise if the the cable was too.
« Reply #4 on: February 18, 2021, 04:28:51 PM »
The visible crimp at the solenoid is wrong, and it should not be visible, as in covered (not painted or shrink wrapped) by a simple sleeve, the same color as the battery connector cover. The battery connector cover should cover the wire connection - it's too short (about 1/2 inch long), exposing what appears to be melted wire insulation.
PS: I prefer the reproductions from Marti Auto.
Offline FXguy
« Reply #5 on: February 23, 2021, 02:32:25 PM »
I appreciate the feedback.  The point of my question was to see if the positive cable went from black with no cover to the red wire with the red terminal cover with the "C4ZF-C" printing and paper label - which is similar (if not identical) to the C5-A that started use in the fall.  The one that I have, that was on the car, had a paper label.  I do have a picture taken of another car in September of 64 that clearly shows a paper label and white printing on an original C5-A cable.
Scott McMullen
