Author Topic: power convertible top  (Read 1038 times)
Offline 65fb
« on: January 14, 2021, 12:27:24 PM »
1966 metuchen   when lowering the convertible top one side does not lower all the way down like the other side. what could be the cause
Re: power convertible top
« Reply #1 on: January 14, 2021, 12:37:25 PM »
weak or leaking cylinder on that side. there is a conv. top manual supplement for the factory shop manual. suggest you seek one out.
« Reply #2 on: January 14, 2021, 12:40:54 PM »
One bad cylinder is one thing that comes to mind . Other causes like joints not lubricated causing binding or a combination could contribute.
« Reply #3 on: January 14, 2021, 03:56:16 PM »
Or a bent arm, sometimes outward.
Offline 65fb
« Reply #4 on: January 14, 2021, 05:28:39 PM »
i do have the supplement. guess it could be the cylinder, but there are no leaks. the top functions fine other than this. arms appear fine.
« Reply #5 on: January 14, 2021, 05:57:56 PM »
the cyl. can have an internal leak. are the lines ok?
Offline 65fb
« Reply #6 on: January 14, 2021, 06:56:25 PM »
yep the lines are ok, so i don't know...... maybe nothing can be done but it seems like there should be a solution, before putting new cylinders on, which i'll do if necessary.  new cylinders were put on when i did the restoration approximately 10 yrs ago and it has always been this way
« Reply #7 on: January 14, 2021, 06:57:26 PM »
'new' does not always equate to working correctly.
Offline 65fb
« Reply #8 on: January 14, 2021, 07:21:51 PM »
yep thats true, but would like to rule out other possibilities before installing new ones
« Reply #9 on: January 14, 2021, 08:15:56 PM »
- but would like to rule out other possibilities before installing new ones
A good approach, but eventually you got to bite the bullet and start replacing parts.
Offline 1966KGT
« Reply #10 on: January 14, 2021, 09:24:42 PM »
I have a 66 and 69 with power tops, would it be possible to unhook cylinder and manually put down? That way may discover the possible binding point.
« Reply #11 on: January 14, 2021, 09:57:51 PM »
+ 1 that is what I would try.
Offline 65fb
« Reply #12 on: January 14, 2021, 10:24:44 PM »
that's a good idea that i hadn't though of
