Author Topic: 68 Hood Latch Date Code Request  (Read 960 times)
« on: January 10, 2021, 05:54:46 PM »
Just using this as a temporary thread to collect some data for updating the Date Coding article in the Library.
Interested in seeing the dates (pattern/letters and numbers) from original hood latches from these two years. Might as well include the source of the latch if know
Thanks for helping
Related discussion in the 1967 Section of the site
http://www.concoursmustang.com/forum/index.php?topic=24000.new#new
A picture to illustrate the two versions. Notice the length of the primary latch section to the left in each for the main design difference. Not unusual to find the incorrect version on a car after years of use, repairs or rebuilding
« Last Edit: January 10, 2021, 08:11:11 PM by J_Speegle »
Offline Keith Stem
Re: 68 Hood Latch Date Code Request
« Reply #1 on: January 12, 2021, 10:43:30 AM »
Jeff
The hood latch date code on my 68CJ is D 23 8. (8F02R185596 Build Date 4/29/68)
Keith
« Reply #2 on: January 12, 2021, 04:35:26 PM »
Thanks - here is another I found in my files
Long guide style also. This one shows a makers mark on the support arm
Offline WT8095
  • Dave Z.
« Reply #3 on: January 21, 2021, 02:01:59 PM »
I don't have access to check the codes on my latch, but if it helps it's the short style. 8R02S140290, build date 16B (16 Feb 1968). Actual build date was 7 Feb.
Dave Z.
« Reply #4 on: January 21, 2021, 02:52:34 PM »
You should not have the short style on a 68. Most likely was c hanged at some point.
