Author Topic: Ignition Wiring at Coil and Dist  (Read 4499 times)
« on: January 07, 2021, 04:35:52 PM »
Thought since I had them I would post these pictures of the routing of the ignition and tach wiring. Hope this helps someone at some point
Period shot of the routing on that particular example originally
- Colors of the highlighting is not an indication of wire jacket color.
- Red indicates the tach wire. Installed at Shelby and have been seen over and under the heater hose on different examples
- Blue is the dist wire and the green the ignition/hot wire to the key. Both routed by San Jose employees
- On this example all were routed is under the heater hose
« Last Edit: January 07, 2021, 05:01:26 PM by J_Speegle »
