Author Topic: 69-70 Radio Delete Panel  (Read 2964 times)
« on: January 03, 2021, 10:15:14 PM »
Thought we had a thread with pictures but it didn't come up in a search. If found I'll merge but I wanted to share a picture of both the standard and deluxe interior versions that I posted elsewhere this last week. Hope it helps someone - currently or in the future
There is a 70 radio delete thread listed before but no pictures
http://www.concoursmustang.com/forum/index.php?topic=3905.0
Re: 69-70 Radio Delete Panel
« Reply #1 on: January 05, 2021, 12:17:01 AM »
Anybody know where a woodgrain delete panel is? thanks
Offline Mike_B_SVT
« Reply #2 on: January 09, 2021, 01:22:57 AM »
Yes.  I'll PM you the contact info.
Mike B.
1 of 354 in Sonic Blue
Cat Bites Man!
Offline Mike_B_SVT
« Reply #3 on: January 09, 2021, 01:30:44 AM »
I recently received some pics of two versions of "radio delete" plates.
I believe this one is the "standard" interior, in black camera case.
PN / Eng#: C9ZB-6504302-N
Mike B.
Cat Bites Man!
Offline Mike_B_SVT
« Reply #4 on: January 09, 2021, 01:37:23 AM »
Woodgrain / Deluxe "radio delete" panel.
PN / Eng#: C9WB-6504302-KW
Any idea why this part has a Cougar part number (C9WB)?  I ran it by the Cougar experts and was told that '69 / '70 Cougars did not use a woodgrain radio bezel, and that the wood grain doesn't match the grain that Cougars used in either the Décor or XR-7 trim.
Mike B.
Cat Bites Man!
« Reply #5 on: January 09, 2021, 01:58:38 AM »
So your contacts are saying they believe the black camera style was installed on Cougars with the MUSTANG across the radio area? Since that is the none woodgrain version
Consider that the casting number may not directly relate to or reflect the wood grain style on the face. Interesting that the people you talked to state that a radio delete panel in a 69-70 was a black camera finish rather than a match woodgrain. Believe I owned one with wood grain that did not match that did not match the Mustang straight grain pattern but didn't take a picture of it before I sold it. Which I would have now since it would be better than just a memory :)
Like often discussion of details expand to other related items. You might or not know that 69 Mustangs also used other parts through the production years that were stamped with 69 Cougar engineering numbers on a regular basis.
« Last Edit: January 09, 2021, 02:16:30 AM by J_Speegle »
« Reply #6 on: January 09, 2021, 02:09:26 AM »
Did follow up with a look at my picture files and even though we're getting off thread a bit (can split if needed) here is a picture of one with an ink stamped identification engineering number to help. Sure someone in the Cougar community has a MPC from 69 or 70 that can look up the number
Might want to show you contacts these pictures or the thread since it can be viewed by non-members in this section. Think the grain pattern is a match. Guessing that not that many of these were made and if the plant didn't have the correct match they may have substituted something
« Last Edit: January 09, 2021, 02:14:55 AM by J_Speegle »
« Reply #7 on: January 09, 2021, 06:45:57 AM »
I did not find the 04302 basic part number in the text section of the 65-72 L-M MPC, so I went to the diagram and noticed that the number we should be using (for the Cougar) is 04774. Refer to picture #1
Part number 04774 was not used on 67-68 or 71 & up, it was only on 69-70 Cougars.  There are "without radio" and "with radio" groups for each of the two years. Refer to picture #2
I went back to the equivalent Ford MPC - refer to pictures 3 & 4.  The Mustang listing is much simpler - black vs. light teak vs. dark teak, then with or without radio.  The Cougar had a wood grain version, but for standard interior the part was color keyed and therefore the MPC has a lot more individual part numbers comparatively speaking.
Unfortunately this is a case where the number cast into the part does not help us identify the service part number.
Offline sah62
« Reply #8 on: January 09, 2021, 08:06:36 AM »
It helps to have a cross-reference manual. The C9WB-6504302-J engineering number cross-references to a C9WY-6504774-C service part number.
Scott Hollenbeck
2019 Lincoln MKZ 3.0T AWD
2003 Mercury Marauder 300A
(more non-Ford stuff)
Offline Mike_B_SVT
« Reply #9 on: January 11, 2021, 11:03:48 PM »
Thanks Jeff ~ not the camera case / black pebble grain with MUSTANG on it (LOL!), but presumably a Cougar equivalent.
The Cougar folks did bring up the existence of the burl grain delete plates though, used on applicable XR-7's.  Matches the pics you posted with the burl grain!
https://secure.cougarpartscatalog.com/c9wb-6504302-j.html
As far as the Cougar part numbers showing up on Mustangs, it's interesting seeing some of the parts that were handed up to the older sibling!
Ah!  So the standard interior version was color keyed!  That would sure add a wrinkle to the rarity of some of them, like red or blue!  D'oh!
WCCC also has a picture of a GREEN radio delete panel in the pebble grain.
https://secure.cougarpartscatalog.com/70radiodelete.html
« Last Edit: January 11, 2021, 11:16:01 PM by Mike_B_SVT »
Mike B.
Cat Bites Man!
« Reply #10 on: January 12, 2021, 12:39:14 AM »
The Cougar folks did bring up the existence of the burl grain delete plates though, used on applicable XR-7's.  Matches the pics you posted with the burl grain![/quote]
Yes different base version compared to Mustang one.  Noticed that at lease one person is again looking into reproducing the plates. Not sure which version they will choose since doing both will double their costs.
Doesn't look green but it is a camera finished flat version - different from the Mustang version
Getting a bit off the original focus may choose to separate this later discussion to appropriate Cougar area
Offline blackjadeboss
« Reply #11 on: January 12, 2021, 11:30:35 AM »
Thanks to Mike for posting the pics of my plates.
I purchased that woodgrain piece in the late 80’s or early 90’s when I was building my 70 Cougar.
I believe it came out of California but that was a long time ago. Also got the firewall and cowl pieces for heater delete. Was told they came out of a car in Hawaii.
Offline JohnSlack
« Reply #12 on: January 16, 2021, 03:28:32 PM »
My 1969 BOSS 302 was originally sold by Bob Brock Ford in Big Spring, Texas. I talked to Bob one time about the car and mentioned the lack of a radio on the order. Bob said, "Right I rarely ordered cars for stock with a radio installed. I sold people the radio....more profit, nobody in West Texas wants a car with no radio!"
9F02G217159 1969 1/2 Dearborn BOSS 302 built July 10, 1969 1 day behind
Calypso Coral 2A 61 DSO V 3.91 Trac-Lok 6 Close ratio Retail Bob Brock Ford
0F02G106990 1970 Dearborn BOSS 302 built September 23, 1969 13 days behind
Lime Metallic EG 71 DSO S 3.50 Trac-Lok 5 Wide ratio Stock John E. Noyes Ford
