Author Topic: Correct Gloss Black Radiator Paint  (Read 3631 times)
Offline vorrath
« on: January 01, 2021, 02:48:50 PM »
what is the correct gloss level on a 69 Mustang radiator ? Thanks
« Last Edit: August 01, 2023, 06:18:54 PM by J_Speegle »
Re: Correct Gloss Black 69 Radiator Paint
« Reply #1 on: January 01, 2021, 04:26:13 PM »
It is kind of a trick question because the gloss black put on the radiator would dull down considerably after a number of heat cycles to more of a  semigloss.
« Last Edit: January 01, 2021, 04:29:44 PM by J_Speegle »
« Reply #2 on: January 01, 2021, 04:29:00 PM »
As discussed in a number of threads a black lacquer paint was likely used that was on the glossy side which quickly flashed and dulled once the car was started and driven
Using the SEARCH feature in the top tool bar and the words "radiator paint" I found the following
http://www.concoursmustang.com/forum/index.php?topic=1441.0
http://www.concoursmustang.com/forum/index.php?topic=12078.msg129263#msg129263
http://www.concoursmustang.com/forum/index.php?topic=23067.msg144353#msg144353
http://www.concoursmustang.com/forum/index.php?topic=8649.msg52443#msg52443
Will merge this thread with one of those to keep the number of threads about the same subject down and the search feature work better ;)
« Last Edit: January 01, 2021, 04:32:41 PM by J_Speegle »
Offline rcgt350
« Reply #3 on: February 21, 2021, 11:57:10 AM »
Is the Eastwood Gloss Black radiator paint a good choice here?
1967 GT 350 W White
1970 Boss 302 GG Restoration in progress
2012 Boss 302 C Orange
1930 Ford Model A 4 Door Deluxe Town Sedan
« Reply #4 on: February 21, 2021, 04:04:32 PM »
Seen owners/builders use it successfully. Keep the paint thickness to a minimal. Cools better that way
NOTE: If someone is wondering the thread was left in this section since the information applies across all years
