Author Topic: Citric acid dipping parts and discussion from Boss 302 forum with pics.  (Read 2694 times)
Re: Citric acid dipping parts and discussion from Boss 302 forum with pics.
« Reply #15 on: December 23, 2020, 11:43:05 PM »
Looks like a great outcome in light of the cost verses the cost of a 5 gallon pail of Evap o rust.
FYI Rust 911 concentrate is only about 4.00 a gallon when you buy the gallon bottle which is enough for 16 gallons.I use it because it is comparable in results yet is much less then evaporust . https://www.rust911.com/rust911-ultra-concentrate-rust-remover-dissolver-treatment-free-shipping/
Offline DougDyar
« Reply #16 on: December 24, 2020, 09:21:04 PM »
Dan
I should have pointed out that my advice to use WD-40 was for parts that were to remain natural and need to be protected from rust.
Obviously a person doesn't want to oil down anything that's to be painted.
I think you have over-thought your predicament. Just re-dip your axle housing in the citric acid treatment. It's a great cleaner as well as rust remover. It'll take off the WD-40. But rinse with hot water this time and skip the wd40! Dry thoroughly and apply primer and paint.
Merry Christmas and Happy New Year!
Doug
0F02G203277
Offline BlackMcode1970mach1
« Reply #17 on: January 04, 2021, 07:00:36 PM »
i think i will try that  procedure  with my dash! ;D :)
