Author Topic: 1967-68 Mustang & Cougar Console Front Compartment Light & Switch  (Read 2075 times)
Offline Z67Fback
Good evening:
Anyone have any pictures where the switch is installed for the 67 deluxe floor console. My console had the light clipped on in the correct place with no switch intact. I found a switch assembly on ebay , but unclear where it mounts. Thank you in advance for any detail
« Last Edit: December 21, 2020, 08:05:04 PM by Z67Fback »
1967 Fastback, C Code, 4 Sp MT, 7T02C226959 Build Date 4/11/67. Built in Metuchen, NJ
Re: 967-68 Mustang & Cougar Console Front Compartment Light & Switch
« Reply #1 on: December 21, 2020, 07:59:11 PM »
It comes on when either door is opened or the headlamp switch is rotated to turn on the interior lights. It plugs in the same harness as the rear console lamp.
« Reply #2 on: December 21, 2020, 08:01:02 PM »
There is no deluxe version of the floor console for 67.   The parts that you pictured are not correct for this.  The 67 console has a light that cycles with the courtesy light.  If nobody posts a picture I can do it later.
Re: 1967-68 Mustang & Cougar Console Front Compartment Light & Switch
« Reply #3 on: December 21, 2020, 08:35:19 PM »
I guess the steel light base might be correct but you are missing the lens.  Wires connect to harness that also picks up the light at the rear of the console. They work as a pair with courtesy lights.
Offline Z67Fback
« Reply #4 on: December 21, 2020, 09:50:27 PM »
Thank you very much. Great info. Make sense. Now I have to see if I can locate the lens
