Author Topic: 68 Dearborn manual steering  (Read 1120 times)
Offline preaction
« on: December 17, 2020, 08:45:19 PM »
There is a thread about most of these parts that is labled San Jose so I wanted to verify if any may be different for a Dearborn car if thats possible. These parts came from one car which is a manual steering car one of my questions is about power steering tie rods are they different shape from a manual steering application ?  Would  the pink paint be typical for a manual steering center link ? The rusty complete tie rod assembly is not part of my  research.
« Last Edit: December 17, 2020, 08:48:17 PM by preaction »
Re: 68 Dearborn manual steering
« Reply #1 on: December 17, 2020, 09:31:11 PM »
Parts books show that service replacements are the same inners and outers for power steering and manual.
Yes pink is typically the make that identifies a manual steering component. You may find a second  colored daub on the center link
Will have to look at some pictures to see if I have any close up's for the hardware and head marks to compare
« Reply #2 on: December 17, 2020, 09:34:43 PM »
The inner and out tie rods are the same PS or manual. For those reading the Drag link is specific to manual and a different style for PS. The top adjusting sleeve that is connected to the tie rods in the picture is a later model replacement.I'll let others comment further.
« Last Edit: December 17, 2020, 09:43:51 PM by Bob Gaines »
Offline preaction
« Reply #3 on: December 18, 2020, 10:53:32 AM »
Jeff, Bob, thanks for the responses. Would the pink assembly ID mark be applied all the way around the link and as wide as the remaining pink paint ? Also only one outside tie rod has a witness mark of yellow paint would this be reppplied as a daub and used on both outer tie rods ?
Offline preaction
« Reply #4 on: December 18, 2020, 10:17:21 PM »
Would the black paint on the steering box  be typical for a late 68 Dearborn also ? In the pic there is some black on the pitman arm IIRC these would be natural ?
« Reply #5 on: December 19, 2020, 12:37:35 AM »
It was painted with a small brush after the box being installed probably while leaning over the front fender reaching down. Consequently applications varied. Although the pitman arm was not meant to be painted I can see paint being dripped onto the pitman arm during the steering box top paint application .
« Reply #6 on: December 19, 2020, 07:07:51 PM »
Normally the worker would not take the time to go all the way around the shaft/rod though if the brush had just been loaded with paint it could have flowed around it as it sat drying. Every one is different sometimes its a daub with runs other times you can see a brush stroke
If I look across the 67-69 period I have mixed findings so would not suggest adding these until we/you have more cars documented. Nice thing is that can be added later with ease given the part and location
