Author Topic: Brake Light Switch Retaining Clip  (Read 1049 times)
Offline 1970 Snake
« on: December 15, 2020, 02:49:17 PM »
Can someone please advise what color code the retaining clip is for the brake pedal mounted brake light switch on a 1970 mustang automatic tranny power disc brake car.
I have both red and greenish-yellow colored retaining clips??
« Last Edit: December 16, 2020, 05:19:46 AM by 1970 Snake »
Dearborn Built Sept 4, 1969
1970 Mach1 428 CJ R-Code C6
dash tach, front bumperettes
Offline RocketScientist
Re: Brake Light Switch Retaining Clip
« Reply #1 on: December 23, 2020, 02:20:56 AM »
I think they are meant to be red.
Brad
Offline 1970 Snake
« Reply #2 on: December 23, 2020, 12:39:07 PM »
« Reply #3 on: December 23, 2020, 12:48:51 PM »
I can't answer the specific question but did some looking and found reference to "pin - self locking" type 2, part number 380699-S2 or 380699-S100 (different finishes) as well as a NN-128-F number.  Some pictures attached.
Did you check Jim's fastener spreadsheet?
« Reply #4 on: December 23, 2020, 02:15:15 PM »
FWIW; 69,4 spd w/PDB. Red
Offline 1970 Snake
« Reply #5 on: December 23, 2020, 04:57:17 PM »
I do not have Jim's fastener spread sheet, but my car is a very early 70 build (Sept 04/69) so it looks like "red" is probably the correct color, based on the data provided, thanks guys, much appreciated.
« Reply #6 on: December 23, 2020, 04:58:05 PM »
yes you do have it. it's in the library section here.
Offline 1970 Snake
« Reply #7 on: December 23, 2020, 05:00:06 PM »
Okay thanks will try to find.
Offline 1970 Snake
« Reply #8 on: January 01, 2021, 04:27:19 PM »
Okay after all that, I finally found the storage zip lock bag I put my interior brake parts in 14 years ago, during disassembly.
I can confirm the clip is "RED", and that the plastic spacer rings white not black like the repops and the switch plastic sleeve is black, and the booster nuts have red dye/paint on them.
Thanks all.
