Author Topic: 69-70 FE starter detailing  (Read 994 times)
Offline calcoral
« on: November 28, 2020, 04:33:33 PM »
looking for pictures of a clean original / nos / or correctly restored C8AF-1101-A cobra jet starter motor  9C20C  date code. mine is now rebuilt and ready for detailing. sorry if it has been asked before but i just heard about this forum last night. thanks in advance for any help ...lee
« Last Edit: November 28, 2020, 04:49:34 PM by J_Speegle »
Re: 69-70 FE starter detailing
« Reply #1 on: November 28, 2020, 04:35:18 PM »
have you tried a search here?? very useful feature and there are not many topics that have not been addressed.
« Last Edit: November 28, 2020, 04:49:47 PM by J_Speegle »
« Reply #2 on: November 28, 2020, 04:49:08 PM »
First welcome to the site - hope you find the information and support here helpful in your concours related endeavors
Since this would be a stater with all the information (enginering, date and such) stamped into the metal main case not allot of detail to worry about. Painted semi-gloss black with a boot over the wire lug and base nut. Paint fades away at the attaching end so that it assures a decent grounding for operation. Make sure there is a heavy paper gasket between the band and main housing as shown in other threads
Offline calcoral
« Reply #3 on: November 28, 2020, 05:12:19 PM »
thanks for the fast replys just now got my search privies so am on it now... any paint dobs or blotches of different colors...lee
« Reply #4 on: November 28, 2020, 05:57:35 PM »
................. any paint dobs or blotches of different colors...lee
Not that I recall ever seeing on originals
Offline calcoral
« Reply #5 on: November 28, 2020, 06:29:43 PM »
thanks again
« Reply #6 on: November 29, 2020, 03:56:24 AM »
To add ,also it has square shaped opening in barrel case plug instead of Phillips,heavy gasket under the Bendix cover ,nose cone with no ribs (1970+ style has ribs ) . Although the ribs on the nose cone can't be seen when installed that style nose cone has a different design of band that can be seen when mounted which indicates it is a later style nose cone. While your at it confirm you have the correct bendix cover given there are several different styles used at different times pre 1966 and post 1970.
