Author Topic: Air cleaner to carb gasket seal questions  (Read 1481 times)
Offline cam shaft
« on: November 25, 2020, 07:02:11 PM »
1. How thick is/are the gasket(s)? c5zz 9654
2. How to get the red color and stripes on the top  side before assembly?.
3. How to attach to the carb or air cleaner?
1970 gt500
Thank you
Re: Air cleaner to carb gasket seal questions
« Reply #1 on: November 26, 2020, 09:05:22 PM »
Would need to dig one out and not sure if I know exactly where one is right now in the garage
Ones I've had were already colored. Guess I would use a red wide sharpie to touch up or make a reproduction
They are "attached" as with adhesive but time, heat and age then tend to bond somewhat with the carb I've noticed likely since it has the wider contact patch
« Reply #2 on: November 27, 2020, 06:12:45 PM »
It's been eons since I've seen an original.
Is the gasket all paper, white or almond with the just the one side red?
Does the color match this:
https://www.ecklers.com/air-and-fuel-system/carburetors-and-related/carburetor-components-and-related/carburetor-top-gasket-paper-composite-as-original-90-39044-1.html
« Reply #3 on: November 27, 2020, 10:17:05 PM »
It is thicker like they glued 3 of the thinner gaskets together.I will try to dig one out and take a picture.
« Reply #4 on: November 29, 2020, 11:17:52 AM »
They are being made now correctly off one of my originals with the red on 1 side
« Reply #5 on: November 29, 2020, 03:29:13 PM »
Who sells them?
« Reply #6 on: November 30, 2020, 03:02:19 AM »
chris brown when they get done,
« Reply #7 on: November 30, 2020, 01:26:32 PM »
Thanks!
Offline preaction
« Reply #8 on: November 30, 2020, 01:46:37 PM »
Fel-PRO sells a gasket that is about 3 times the thickness as a standard gasket its black but is a good part to get the thickness for the height of an air cleaner so stock parts like a "S" tube fit well.  Fel-Pro 60032
Offline Coralsnake
« Reply #10 on: November 30, 2020, 05:09:05 PM »
This is what they look like.
Offline rockhouse66
« Reply #11 on: December 01, 2020, 09:27:38 AM »
Holley also offers an extra thickness gasket.
https://www.summitracing.com/parts/hly-108-62
'66 GT FB
« Reply #12 on: December 01, 2020, 01:18:28 PM »
Finding a gasket that will function in place of is not the issue. Finding a gasket that looks the part of the assemblyline part is . ;)
