Author Topic: 65 Dearborn Front Spring Cover Hardware  (Read 578 times)
« on: November 15, 2020, 03:51:09 PM »
The subject came up in another thread so wanted to provide a thread so we can focus and discuss the direction and need be the original details related to the bolts and nuts that retained the front spring covers on 1965 Dearborn built cars
Origination thread http://www.concoursmustang.com/forum/index.php?topic=23659.0
Example. Upper (along top of the inner fender panels and shock tower bolts were installed with the nut in the wheel well. What is being discussed so far is the direct on installation and nut location on the remaining, lower, size nuts and bolts. Typically this is a result and believed to be different depending on assembly plant and what worked best for those workers and possibly different due to the way the line or station is designed in that area.
These are often installed during a restoration matching locally seen cars rather than as found or representing the cars original assembly plant. We have often seen the same practice applied to other factory details.
A unrestored (everything has been rattle canned black) 1965 Dearborn example and the same configuration of the first 100 examples I've looked through so far in my survey
« Last Edit: November 15, 2020, 06:42:12 PM by J_Speegle »
Re: 65 Dearborn Front Spring Cover Hardware
« Reply #1 on: November 15, 2020, 07:58:54 PM »
SO look through all my pictures and looking at the results there was really no reason to make a graph since my findings were that 100% of the unrestored cars I have pictures from 65 at Dearborn had the bolts installed as shown about. There was one car/example where the bolts (lower six) were installed in reverse of the above direction but those bolts had been removed and replaced at some point in the past. In the picture below you can see that the sound deadener/undercoating over the bolt have been disturbed as shown in the picture below. Drivers side hardware was undisturbed  and bolt direction was with the nut on the engine side
While I have a list of the cars I used for the survey I thought I would at least post them (altered a little) to show that there was a pretty good representation across the production year
5F1000xx
5F1000xx
5F1021xx
5F1045xx
5F1132xx
5F1125xx
5F1129xx
5F1163xx
5F1173xx
5F1182xx
5F1244xx
5F1242xx
5F1261xx
5F1313xx
5F1356xx
5F1356xx
5F1376xx
5F1436xx
5F1447xx
5F1531xx
5F1554xx
5F1555xx
5F1578xx
5F1581xx
5F1601xx
5F1609 xx
5F1625xx
5F1686xx
5F1717xx
5F1738xx
5F1769xx
5F1769xx
5F1781xx
5F1799xx
5F1800xx
5F1842xx
5F1843xx
5F1871xx
5F1876xx
5F1954xx
5F1987xx
5F1999xx
5F2004xx
5F2018xx
5F2044xx
5F2056xx
5F2060xx
5F2087xx
5F2181xx
5F262xxx
5F268258
5F2683 xx
5F2697xx
5F2706xx
5F2726xx
5F3278xx
5F2798xx
5F28xxxx
5F2818xx
5F2964xx
5F2971xx
5F3000xx
5F3054xx
5F3108xx
5F3110xx
5F3125xx
5F3143xx
5F3151xx
5F3365xx
5F3402xx
5F3451xx
5F3475xx
5F3490xx
5F3531xx
5F3617xx
5F3636xx
5F3638xx
5F3637xx
5F3645xx
5F3658xx
5F37xxxx
5F3728xx
5F3756xx
5F3775xx
5F3788 xx
5F3945xx
5F3960xx
5F3967xx
5F3981xx
5F3987xx
5F3791xx
5F3989xx
5F6003xx
5F6036xx
5F6084xx
5F6111xx
5F6287xx
5F6310xx
5F6335xx
5F6408xx
5F6680xx
5F6700xx PS backwards
5F6759xx
5F6766xx
5F6787xx
5F6821xx
5F6893xx
5F7013xx
5F7016xx
5F7023xx
5F7036xx
5F7275xx
5F7341xx
5F7370xx
5F7396xx
5F7404xx
5F7406xx
5F7501xx
5F7532xx
5F7562xx
5F7768xx
5F7806xx
5F7911xx
5F7949xx
5F7977xx
5F8021xx
« Reply #2 on: November 15, 2020, 07:59:44 PM »
While we're at it here is a close up of the head marking from 5F07C7806xx. Appears to be the anchor head design
