Author Topic: Voltage Regulator - 1967 Convertible With Power Top and Without A/C  (Read 2152 times)
Online 196667Bob
Re: Voltage Regulator - 1967 Convertible With Power Top and Without A/C
« Reply #15 on: November 15, 2020, 07:43:07 PM »
I firmly disagree. I have provided a significant amount of evidence that shows that only a 38 amp Alternator is required for the Power Top. I have seen no evidence that a 55 amp Alternator is required for the Power Top.
I believe that the shoe is on the other foot.
Bob
MCA 04909
« Reply #16 on: November 15, 2020, 08:22:45 PM »
Occams razor:
SIMPLE way to check (if it ALSO hasn't been replaced).
What size battery tray do you have? 22F or 24F.
« Reply #17 on: November 15, 2020, 08:36:02 PM »
In all my years working on various Mustang harnesses, I have yet to run across a 20 gauge wire.  The smallest is 18 gauge, the usual is 16.  Power-hungry lines, such as wipers, horns, etc., are 14 gauge.  Power sources (ACC, battery) are 10-12 gauge.
« Reply #18 on: November 15, 2020, 09:29:35 PM »
Bob
Then I suppose we can at least agree to disagree . ;)
« Reply #19 on: November 15, 2020, 09:37:27 PM »
Your missing the point . Regardless of the gauge of the A/C wire it is obvious (isn't it?) that the power top feed wire is a heavier gauge wire which logically indicates it carried a heavier load.
Offline rodster
« Reply #20 on: November 15, 2020, 09:51:10 PM »
FWIW, I have factory AC, COMBINED with a different anomaly...my Marti Report doesn't list H.D. Battery option AND I had (yes, I said "had") a "dated correct" 22F battery tray in it.
Research at this forum has convinced me that my example OUGHT TO HAVE BEEN BUILT with the 24F battery and 55 amp alternator and certainly it makes better sense to have MORE amperage available than LESS amperage. I updated my battery tray. After all, it ALSO relieved me of hunting down a 22F battery that is essentially unobtainable.
Dependent on engine size?
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
« Reply #21 on: November 15, 2020, 10:12:34 PM »
True.  The current need of the power top is probably on the order of 10 amps, so a 20 amp circuit breaker would be called for (a safety factor of 2 is what I find Ford liked to use).  Nevertheless, a 10-15 amp draw for 30 seconds doesn't require a larger alternator as the battery itself can handle that short-time draw.  The alternator is there for recharging the battery, not for primary electrical current draw.
« Reply #22 on: November 15, 2020, 10:24:58 PM »
I tend to think that A/C cars would require a better battery/alternator due to heat soak, not that A/C required those parts or electrical energy to run. Heat soak would cause the starting system to have to work much harder.
« Reply #23 on: November 15, 2020, 11:56:09 PM »
Previous discussion regarding alternator ratings...
https://www.concoursmustang.com/forum/index.php?topic=19345.0
Offline mtinkham
  • That'll be easy
« Reply #24 on: November 17, 2020, 01:56:47 PM »
Maybe the wire size is also considering the length of the wire run?
