Author Topic: 1967,1968 Mustang Bracket to Radiator Support (qty2)  (Read 672 times)
Offline Craners
« on: November 14, 2020, 08:48:02 PM »
Wanted qty 2, Mustang Hood Rubber Support Brackets.
C7ZZ16A714-A
NOS Qty 2
These are the brackets that are spot welded to the radiator support panel.
Thank you
Fran
Re: 1967,1968 Mustang Bracket to Radiator Support (qty2)
« Reply #1 on: November 14, 2020, 09:34:12 PM »
C7ZZ16A714-A
NOS Qty 2
Thank you
Fran
I hope that you find the NOS brackets but you may want to have plan B with used ones just in case  ;)
Offline Craners
« Reply #2 on: November 14, 2020, 09:37:54 PM »
I just realized these brackets are date coded.
No longer searching for NOS, unless they are date coded.
Searching for used with date code for late 1968 Cobrajet GT500KR
Thank you.
« Reply #3 on: November 14, 2020, 10:59:44 PM »
Thank you.
A already proper date code is the way to go however FYI it is easy enough to add a proper date code to a used set with a little work .
« Reply #4 on: November 15, 2020, 05:05:37 PM »
The challenge I would find on these specific parts and adding/changing a date would be that they appear to have been date stamped before they were formed so gign to be a challenge to get a stamp in the corners/along the edge as shown below.
« Reply #5 on: November 15, 2020, 09:14:03 PM »
What date are you looking for?
Offline Craners
« Reply #6 on: November 17, 2020, 10:37:37 PM »
As far as determining  what date I need..
The brackets that are on the car are date coded, but these have “rewelded” from a collision repair.
They might be dated correct, but I really can’t pick out the date.
Part of the date stamping is also on the formed corner, which adds to my confusion.
Is there a simple decode for that stamping?
Thank you
Fran
« Reply #7 on: November 18, 2020, 08:29:37 PM »
Thank you
Fran
[/quote]
Have you looked through the article on date codes in the Library as a start?
As see these are often not as clear as those stamped on flat sheet metal but the article would be a starting place
