Author Topic: Deluxe steering wheel  (Read 1484 times)
Offline rocnhrse
« on: November 05, 2020, 08:35:07 PM »
I obtained a  excellent  deluxe  steering wheel, which  I would  like to install  in my 67 that has the deluxe  interior but a standard steering wheel.
Before I  jump into this,is it a simple swap, or is it more  involved than that.
67 mustang  GTA  S code fastback  San Jose  April 67
Offline 196667Bob
Re: Deluxe steering wheel
« Reply #1 on: November 05, 2020, 10:24:22 PM »
Yes, this can be a simple swap ; that is if you have all of the special additional parts that are required for the Deluxe Steering Wheel that are either different or not required for the Standard Steering Wheel. Hopefully, you received all of them with the Steering Wheel itself ?
Illustrations of both are attached.
Bob
« Last Edit: November 06, 2020, 08:17:30 PM by 196667Bob »
MCA 04909
Offline rocnhrse
« Reply #2 on: November 06, 2020, 08:46:04 AM »
No,all I got was the wheel,I will study the drawings,and shop for more  parts
« Reply #3 on: November 06, 2020, 03:14:36 PM »
A picture of what you DO HAVE could help...there are some pieces that only original parts will help you. Other pieces (at times) might be available aftermarket.
« Reply #4 on: November 06, 2020, 04:16:12 PM »
Bob,
I think the third picture is 65-66 only. The number ID in the lower corner, P-4955 is reference on the 65-66 drawing.
Offline 196667Bob
« Reply #5 on: November 06, 2020, 08:16:50 PM »
Jim : I agree with you. I "grabbed" it right out of the "1967 Only" MPC, and didn't really check it, just incorrectly assuming that it was 1967. After you brought it up, I looked at my "1966 Only" MPC, and sure enough, same exact illustration. Just another case of Ford grabbing a previous drawing without checking the details.
I'll go back and remove it to avoid any confusion. If someone comes up with documentation of  1966 Deluxe Wheel and components being used in 1967, we can address it then.
Thanks for catching this.
Bob
« Last Edit: November 07, 2020, 12:46:59 AM by 196667Bob »
MCA 04909
Offline 196667Bob
« Reply #6 on: November 07, 2020, 12:39:31 PM »
Referring to the second Illustration I previously Posted, following are the complete Service Part Numbers of those parts that are different from, or in addition to those for the "Standard" (non-Wood Grain) Steering Wheel.
If a part on the Illustration is not listed below, it is either the same as the non-Wood Grain Steering Wheel, or in the case of 13A848, it was not available as a Service Part.
C5ZZ-3491-A (w/o PS)
C7OZ-3491-A (w/PS)
C7OZ-3600-S (w/PS - 16" dia)
C7AZ-3600-T (w/o PS)
C7ZZ-3623-H thru -P (Depending on Interior Color)
C7OZ-3656-A (w/PS)
C7OZ-3656-B (w/o PS)
C5ZZ-3C3680-A
C7OZ-13A805-B
C5ZZ-13A807-B (3 required)
C7SZ-13318-B (ONLY w/ TILT WHEEL)
C6OZ-13A832-A
C7OZ-13A865-D
C6OZ-13A889-A
C5ZZ-13A890-A
C5ZZ-13A891-A
44710-S (#8 Flat Washer - 3 required)
52792-S (#6-20 x 5/8", pan head phillips, self tapping)
52812-S ( #6-20 x 1", pan head phillips, self tapping - 3 required)
Hopefully, I haven't missed anything.
Hope  this helps.
Bob
MCA 04909
Offline rocnhrse
« Reply #7 on: November 07, 2020, 01:57:24 PM »
Thanks Bob, it does  help,I  will  get through the list,I tried  to post pictures  but didn't have any  luck,must be doing  something wrong
9TO2Hknot4cell
  • Guest
« Reply #8 on: November 08, 2020, 02:02:37 PM »
rocnhrse, PM me. I have parts for a 67 deluxe wheel for sale.
