Author Topic: Correct Date Code Heater Hose  (Read 1098 times)
Offline 1970 Snake
« on: November 02, 2020, 01:10:48 PM »
Apparently there are only two date codes available on heater hoses for a 1970 428 CJ mustang. These repro hoses are with the red Autolite markings, strips and grooves.
Available date codes are H9H04B Nov 4, 69 and H8H02A Nov 2,68. My car was Dearborn built Sept 4, 1969 so would the H8H02A hose be correct or is the H9H04B correct as the vendors are saying that the later is for a 1970 mustang built before Jan 1970. The H8H02A hose marking seems quite early for a 1970 mustang and vendors are designating it as correct for 1969 mustangs.
Dearborn Built Sept 4, 1969
1970 Mach1 428 CJ R-Code C6
dash tach, front bumperettes
Offline DougDyar
Re: Correct Date Code Heater Hose
« Reply #1 on: November 03, 2020, 11:40:17 AM »
I would say that neither one is "correct".
Obviously the Nov '69 date is after your car was built, so that one's out of the question.
The Nov '68 version could technically have been used when new, but likely wasn't as the date is almost a year before your build date. A few weeks to a few months before would be more believable.
Given only those two choices, I'd go with the Nov '68 version.
0F02G203277
« Reply #2 on: November 03, 2020, 02:04:13 PM »
...and of course neither are correct for a September 1968 car.  Brian
Offline 1970 Snake
« Reply #3 on: November 03, 2020, 03:51:38 PM »
Mine is a Sept 1969 car NOT 1968
« Reply #4 on: November 03, 2020, 06:03:30 PM »
Kevin Marti only makes that date on the red striped hoses for "without A/C" heater hoses. Yellow came later, and the cutoff date is 2/1/1970ish.
I thought that "H" month was August?
Offline 1970 Snake
« Reply #5 on: November 04, 2020, 07:26:03 AM »
I believe you are correct regarding the date code "H" = Aug and not Nov, which would make more sense. I did not check these codes, only pasted on what the NPD website defines as the date codes.
And if in deed the date code H9H04B is Aug 1969 then that would be the correct hose for my car and not the H8H02A.
