Author Topic: Space Saver Bottle Tie Down Spring  (Read 701 times)
Offline 1970 Snake
« on: October 27, 2020, 05:37:33 PM »
Can someone please advise what the finish is on the tie-down spring for the 1970 space saver tire inflator bottle.
Dearborn Built Sept 4, 1969
1970 Mach1 428 CJ R-Code C6
dash tach, front bumperettes
Re: Space Saver Bottle Tie Down Spring
« Reply #1 on: October 27, 2020, 05:44:27 PM »
Recall it being a phosphate (sort of flat grey plating) like finish. Sure others will double check my comment ;)
Offline 1970 Snake
« Reply #2 on: October 29, 2020, 03:22:29 PM »
Thanks Jeff, my repro came in black paint and I did not think that was correct. I would prefer to zinc plate it but there is not a zinc plating that comes in that phosphate look, so will probably plate it in black zinc which is an off black charcoal color, and a little closer to the phosphate look.
Offline PerkinsRestoration
« Reply #3 on: October 31, 2020, 06:19:13 PM »
Semi - Gloss black is typical.
Offline 1970 Snake
« Reply #4 on: October 31, 2020, 06:28:19 PM »
Much appreciated Bob, thanks.
