Author Topic: power steering parts  (Read 1936 times)
Re: power steering parts
« Reply #15 on: October 31, 2020, 12:38:57 AM »
Solved! The bolt (304759-S2) and nut (34443-S7) are documented in the 67 Chassis Assembly Manual (AM0020) page 43. I'll expand tomorrow.
« Reply #16 on: October 31, 2020, 04:25:48 PM »
The above apply to 68 and earlier Mustangs with power steering.
For the 1969 application, the correct hardware is: bolt, 383400-S100, 5/16-18 X 1 1/2 in L, 1.0 in thd L (no grade listed, -S100 specified on drawing, probably red); nut, 382634-S100, 5/16-18 Hex 1/2 drive, 0.292-0.302 in thk, GR 5 (-S100 specified on drawing, probably red); shown in AM0030 pg 74 (section D-D, upper RH corner).
If you do not have a copy of the Mustang Assembly Manuals for your year car, I strongly suggest you get a set.
« Reply #17 on: October 31, 2020, 07:17:56 PM »
Good, I didn't wish to chase mine down (though car currently sits on a lift, mostly assembled) but I KNEW without a doubt, it was 5/16" too. I just assembled this area a few months back and paid very close attention to the Assembly manual on that detail and was clear it was 5/16"-24.
« Reply #18 on: November 01, 2020, 04:53:33 PM »
To recap:
The bolt, nut and washer shown in the 60-68 Ford Car Parts (aka MPC) and the 75 edition are incorrect (SEC37 pg12 under part number 3A730, Valve Assy, and ILL 35 pg32 - REF P-4180). These are 3/8 inch hardware, the correct size is 5/16 inch.
For 1969 and 70, the bolt is 383400-S100 and the nut is 382634-S100. They quite possibly have a red dye. They are documented in their respective Mustang Chassis Assembly manuals. No washer is used.
For 1977 and 68, the bolt is 304759-S2 and nut is 34443-S7. They are documented in their respective Mustang Chassis Assembly manuals. No washer is used.
For 1964, 65 and 66 V-8 engines only, the bolt "may" be 304759-S2 and nut "may" be 34443-S7. They are NOT documented in the 64/65 Mustang Chassis Assembly manuals. The 67/68 hardware is assumed. No washer is used.
« Last Edit: November 01, 2020, 07:30:02 PM by jwc66k »
