Author Topic: power steering parts  (Read 1934 times)
Offline kammertime
« on: October 26, 2020, 05:07:21 PM »
I need the bolt, nut and washer (if required) for the clamp on the control valve to drag link. NPD has the kit (3B739-1A) but I have the clamp.
I can't find the part numbers in any of my books. Any ideas ?
Re: power steering parts
« Reply #1 on: October 26, 2020, 05:52:50 PM »
First to illustrate to others what your referring to
Have you checked the Hardware list, Assembly Manuals and a MPC?
« Reply #2 on: October 26, 2020, 07:53:58 PM »
I think this is what you are referring to. Unfortunately, it's the service drawing and not the original assembly line. What you can get from the drawing is the bolt diameter (3/8 inch), and approximate length (1 1/2 inch).
« Reply #3 on: October 27, 2020, 11:31:28 AM »
You sure about that? The bolts are 5/16-18 NC. Finish is very dark, looks like a carburized bolt.
« Reply #4 on: October 27, 2020, 12:30:16 PM »
Nope. I'm inclined to agree with you, but the bolt is in a heavy duty application. The service replacement bolt is 20469-S (locator B-174) as shown in my previous post. The specs for it are 3/8-24 X 1 1/2 in L, GR 2, 1 inch thread length, 9/16 hex. I can't get to my 65 GT Fastback with power steering to see what is there. As to finish, the service replacement bolt has none specified. A "dark" finish might be phosphate.
Offline kammertime
« Reply #5 on: October 27, 2020, 05:08:01 PM »
I found a drawing I can read.
Bolt   20469-S (B-174)
washer  34807-S  (X-66)
Nut  33800-S (M-63)
I must admit that I don't know how to interpret these numbers.
I don' have an MPC if that is where they are found. What are the letters/numbers in ().
« Reply #6 on: October 27, 2020, 05:11:47 PM »
Nut  33800-S (M-63)
Get this manual to help decipher.
« Reply #7 on: October 27, 2020, 05:42:30 PM »
......................I don' have an MPC if that is where they are found. What are the letters/numbers in ().
Using the search feature I found the following thread that offers a link to one - be it the later one there still is some value though you need to double check many details (assembly line verses replacement, but its a place to start. Used "MPC download" for the search
http://www.concoursmustang.com/forum/index.php?topic=22691.msg142174#msg142174
« Reply #8 on: October 27, 2020, 07:15:21 PM »
For reference, the service part number "locator code" references this finish:
20469-S8 (B-174)
34807-S8 (X-066)
33800-S8 (M-063)
S-8 is a clear zinc finish, and may NOT represent the assembly line part's finish.
(Lots of disclaimers when using Ford Service Part - aka MPC).
« Reply #9 on: October 27, 2020, 08:49:35 PM »
I don't know anything about service replacement parts. The OEM bolt and nut are 5/16"-18 NC and I don't see how a 3/8" diameter fastener could work in a 5/16" hole.
« Reply #10 on: October 29, 2020, 07:40:36 PM »
From the Cold War, a baby carriage factory, in (as in "Back In The -") the USSR, no matter how they workers attempted to put the stolen baby carriage together, it always came out as a machine gun -
Here's another picture of what Ford said the service parts were - all 3/8 diameter.
And a picture of the only undercarriage I could get to (yeah, it's a 66) - I measured the bolt end - 0.365 in dia.
I will pose this again - are we all on the same page? Can someone crawl under a car and verify what this thread is all about?
« Reply #11 on: October 29, 2020, 08:59:02 PM »
I can't find the one for the 67, so I grabbed one that appears to have a 68 date code on the cap. I parted this car out in 1985 or so.
The head is marked RSC and is a 5/16x24 NF with proper cone nut.
edit -- corrected to RSC
« Last Edit: October 30, 2020, 08:33:36 PM by Bossbill »
« Reply #12 on: October 30, 2020, 12:21:59 AM »
Bill,
If you would, some more details: bolt length, thread length, hex drive (should be 1/2 inch), and a picture of the nut, height and drive.
Was there a washer?
I would like to identify the hardware by Ford part number and enter that data in the Hardware Spreadsheets, cross referenced from the incorrect Ford service data.
« Reply #13 on: October 30, 2020, 12:32:49 AM »
Will do that tomorrow.
I need to find the Shelby one too.
« Reply #14 on: October 30, 2020, 08:33:02 PM »
Needed a loupe to finally see RSC with the 3 slashes for grade 5.
5/16x24 NF
1/2 bolt flats
Total length is 1.720
Length under head 1.50
Thread 1.025
0.307 largest diameter non-threaded portion
Black oxide finish
Cone style locking nut
Nut is 5/16x24 NF
1/2 bolt flats
Cone nut possibly S7
Total height 0.330
No washer
Clamp has indexing punch in top
Hole is 0.320
Natural
On edit add pics
« Last Edit: October 31, 2020, 01:16:32 PM by Bossbill »
