Author Topic: Pot-Metal adhesive?  (Read 3488 times)
Offline Angela
Pot-Metal adhesive?
« on: October 25, 2020, 06:43:53 PM »
Hey guys, what do you recommend for adhesives which will adhere to the pot-metal used in the quarter panel end caps or headlight buckets?
I frequently see cracks in the lower section of 69/70 quarter panel end caps. I see similar cracks in the 67/68 headlight buckets where the valance connects.
I've thought about using 3M 2-part structural adhesive but I thought I'd ask for recommendations first.
Thanks.
Re: Pot-Metal adhesive?
« Reply #1 on: October 26, 2020, 04:40:06 AM »
Muggy Weld is a brand of solder that works very well.
Offline BKnapp
« Reply #2 on: October 26, 2020, 08:37:58 AM »
‘67 390 Coupe A/T  P/S  P/B. (Built 1/4/1967)  7R01S145xxx
‘67 390 FB A/T P/S P/B (Built 3/10/1967) 7F02S173xxx
2007 Shelby GT500 40th Anniv.  Convert. #125
« Reply #3 on: October 26, 2020, 09:20:46 AM »
An alternative to adhesive, admittedly straying from the request, is to use a very low temperature electrode and a TIG welder.  Fortunately I have a good friend that is an expert in this area and he can do wonders, including rebuilding busted off "studs" on a 67 lower back panel grille.
Offline Coralsnake
« Reply #4 on: October 26, 2020, 10:03:55 AM »
Does anyone have a muggy meld repair service? It looks great, but never seemed to work for me?
This guy can do wonders:  potmetal.repair/about-james-ruther/
I was very satisfied with his work repairing carburetor air horns.
Offline ExportMach
« Reply #5 on: October 26, 2020, 01:34:48 PM »
One of my head light buckets had a broken tab, I found a repair kit that used J-B Weld. It was simple and effective.
Mark C
Online jwc66k
« Reply #6 on: October 26, 2020, 02:03:57 PM »
I've repaired several 64-66 headlight buckets with the JB Weld kits. No problems at all. JB Weld is not a fix all product, but it is good on non stress metal applications.
« Reply #7 on: October 26, 2020, 02:18:17 PM »
Using a wetted wood backing, I filled the missing portion in, following the YouTube videos I saw 4 or 5 years ago.
I didn't quite get enough "fill" the first time up but round two was good. Sanded off the front and back sides, drilled out the hole. It held on final assembly too.
I am not a welder by trade. It can be done by anyone.
Offline Coralsnake
« Reply #8 on: October 26, 2020, 08:28:17 PM »
Excellent results!
