Author Topic: 1967 motor mounts for Small Blocks 2 Versions  (Read 2027 times)
Offline qman
« on: January 23, 2011, 08:18:45 PM »
 I tried to find an answer on another Mustang site, but no luck.  Can someone explain why Ford had two different motor mounts for the 67 small block Mustangs. I see that some are called tall mounts while others are called short mounts and the tall mounts are for convertibles while the short mounts are for coupes and fastbacks ( I think I've got this right). In the end it seems to have nothing to do with engine position in the engine bay.
« Last Edit: April 07, 2024, 04:43:57 PM by J_Speegle »
Re: 1967 motor mounts
« Reply #1 on: January 23, 2011, 09:43:16 PM »
I have run into this before we had to change the hard mount to make it work. But I do not know why Ford had two differant mounts. Marty
« Reply #2 on: January 23, 2011, 10:15:21 PM »
I've heard that convertibles used lower mounts, but have never verified that through observation and documentation.
« Reply #3 on: January 23, 2011, 10:31:54 PM »
Offline qman
« Reply #4 on: January 24, 2011, 11:17:18 AM »
Thanks so much for the help.  Talked to those folks this morning and ordered the motor mounts. Quentin
« Reply #5 on: January 25, 2011, 12:14:58 AM »
Very interesting thanks Carlite 65
« Reply #6 on: January 25, 2011, 01:29:01 PM »
I know that on  69 GT350 conv (at least 15 or so that i have worked on over the years) because of tight hood clearance on that model if you don't use the convertible smallblock mounts the a/c brket will hit the hood. I have seen the tell tale under hood chip marks on many others that didn't use the correct convert mounts. This supports a observation that the convertible motormounts are shorter. Bob
