Any comments on the Scott Drake ashtray?
How close to original? The pics don't tell me much. Would need one in hand to see.
It appears there is no such thing as an original ashtray that isn't pitted to death.
Side by side, they are a good match. The visible face that is riveted on is ok but stamped with distortion that can be reworked or used as is but I chose to use my original face and rivet it onto the liner after it was painted (like the factory did).
Here's the kickers I had. You knew there would be..
1.) The plating process leaves an internal corner unplated. I returned my first one to NPD Michigan and asked that they look at their replacement before shipping. He said they were all like this, all he had on hand anyways.
The solution to this defect is to have the new liner replated.
2.) The latch, or tab that you push down, does not catch the receiver side correctly (the receiver side is the original bracket that screws into the dash, it is not provided with the new ash tray). Re-plate your original "tab" and re-use it.
Note: when replating your original receiver bracket, be careful to protect the hinge pin. The hinge pin is attached at the bottom of the bracket.. Mine came back from the plater WITHOUT the hinge pin. We are not sure how this happened but wonder if an acid dip I used before sending it, dissolved the rivets or retainers and it fell out.
