Author Topic: 1970 San Jose hood moulding clips with dome nuts?  (Read 892 times)
Offline silverelvis69
« on: October 19, 2020, 06:50:23 AM »
Hi Gang,
Any ideas where I can get this??
The scott Drake stuff or after market are not quite the same?.
San Jose built
11/69
Dark ivy green metallic
Ps A/c
Re: 1970 San Jose hood moulding clips with dome nuts?
« Reply #1 on: October 19, 2020, 07:19:46 PM »
Likely going to have to get some from a donor car. Might want to research to see what else they may have been used on (possibly bigger Fords that year) to increase your possibilities
« Reply #2 on: October 19, 2020, 08:10:25 PM »
Hi Gang,
You would probably do a bit better if you knew the Ford part number.
« Reply #3 on: October 19, 2020, 11:10:09 PM »
1970 Parts and Part Numbers:1970 Hood Lip Moulding D0ZZ-16856-A
Retainer ClipD0ZZ-16A746-A
Retainer Nut384102-S100
Hood Front Moulding Support D0ZZ-16C694-A
Rivets375203-S
San Jose built
11/69
Ps A/c
« Reply #4 on: October 20, 2020, 12:40:06 AM »
Rivets375203-S
That's close. I used several sources and found no reference to the nut, 384102-S100, mostly because it was replaced by 377523-S100, a stamped nut. The nut is not shown as being included with the molding as service item. Your best option it to find used and have them replated. You can add 69 Fairlane and Torino to your search as they "may" have used 384102-S100 as they both used 377523-S100 as a service replacement.
