Author Topic: 66 A & C Code Thermactor Thread  (Read 1213 times)
« on: October 18, 2020, 11:53:39 PM »
Realized that we have never really set aside a thread to collect details and parts that make up the 66  Thermactor systems installed for cars intended for California in that year. Some of the parts exchange with 67 but we have to start with. Will likely start one over in the 67 area since not all details are the same.
Just posted these in another post on another site so sharing them here also
The unused port is not drilled out - casting still there. Rear plate needs to be cleaned, painted and machined surfaces returned then oiled
Look at the front of the pump
Look at the date codes - casting and assembly In this case this was made for an early 1966 289
« Last Edit: October 19, 2020, 07:56:36 PM by J_Speegle »
Re: 66 A & C Code Thermactor Thread
« Reply #1 on: October 19, 2020, 12:55:18 AM »
The "backfire" brackets, two piece early 66 with attaching hardware and late 66 single piece, plus manifold attaching hardware and backfire attaching hardware.
« Last Edit: October 19, 2020, 07:56:45 PM by J_Speegle »
« Reply #2 on: October 19, 2020, 01:12:10 AM »
Pump adjustment arm spacers
« Last Edit: October 19, 2020, 07:56:52 PM by J_Speegle »
« Reply #3 on: October 19, 2020, 01:13:11 AM »
Pump deflector. Postioning/clocking is important will add that later to this post
The casting date of the main pump cast. Assembly date is on a curved machined surface found on one of the exterior "fins" for lack of a better descriptive term
« Last Edit: October 19, 2020, 08:09:34 PM by J_Speegle »
« Reply #4 on: October 19, 2020, 01:16:19 AM »
Spark plug wire re-locator brackets. Three of them
Passenger forward version. Car was really dirty with a very fine dust on it from years of storage in a business that created the dust
Drivers side example. Longer one shown above
« Last Edit: October 19, 2020, 08:18:40 PM by J_Speegle »
« Reply #5 on: October 19, 2020, 01:16:51 AM »
Large hose - pump to air filter connection
« Last Edit: October 19, 2020, 07:57:19 PM by J_Speegle »
Offline Deuce
« Reply #6 on: October 19, 2020, 09:51:57 AM »
This is excellent, thank you.  Will be looking forward to a 67 289 Thermactor Thread.
« Last Edit: October 19, 2020, 07:57:29 PM by J_Speegle »
Deuce
« Reply #7 on: October 19, 2020, 08:03:11 PM »
On a A or C code engine with Thermactor and AC the drivers side hose passes by (to the rear0 the AC pump and to reduce rubbing and vibration is held to the pump with a simple rubber coated clamp.
« Reply #8 on: October 19, 2020, 08:06:34 PM »
At the rear of the engine the valve was plumbed/attached to the engine air cleaner with the use of a pre-shaped hose
Hose not fully seated on the nipple
« Reply #9 on: October 19, 2020, 08:15:50 PM »
Some more of the same items Jim posted in Reply #1
C6OE-D valve to intake bracket. Brackets and spacer were all painted semi-gloss black as Jim's post shows
Spacer example with hardware details. Head are the RBW type
Wonder how much trouble someone got in by messing up and either making the bracket too short or not having a bracket made for the wrong valve =?
« Reply #10 on: October 19, 2020, 08:17:19 PM »
Two of the longer hoses and their markings
« Reply #11 on: June 18, 2021, 03:25:19 PM »
Adding a picture to show the vacuum fitting at the rear of the intake manifold. This example shows the connections
Large threaded hard line to rubber hose for a power brake supply, larger nipple connection for the automatic transmission vacuum source and the small nipple for the thermactor valve visible at the rear of the intake manifold
NOTE: Someone rattle canned the area in the picture with blue engine paint so finishes and colors are not correct or original :)
