Author Topic: Another 69 428 SCJ question  (Read 2479 times)
Offline YELLOWBOSS2
« on: January 21, 2011, 07:57:34 PM »
This car is a late 69 428 SCJ. It is a R code, it has it's original engine with the original oil cooler, original jumper wire for the horns and a 9" rear end with a close ratio std transmission. The question comes from the axle ratio.  The door tag has a A code for the axle which is a open 3.50. Is it possable for a SCJ to have this axle ratio?
Dave
« Last Edit: January 21, 2011, 08:00:53 PM by YELLOWBOSS2 »
Offline svo2scj
Re: Another 69 428 SCJ question
« Reply #1 on: January 22, 2011, 02:29:42 AM »
Well you know that isn't correct for a SCJ - and oil coolers and horn can be added even back then !
Being a LATE car I would guess that you will find out more about it - either through a Deluxe Marti or on disasembly of motor (finding NO other SCJ internals).
Now if there are other items like, special DSO or you know the car was to be used specifically by Mag/Ford there could be a reason.
But with 20K NON SCJ built compared to 2000 or so odds are it isn't correct.
Do you have an build sheet?
Mark
Offline YELLOWBOSS2
« Reply #2 on: January 23, 2011, 12:57:34 PM »
Mark,  You are right I think I know the answer.  The motor in this car is a SCJ motor. It has the correct rods, Harmonic balancer and all the other good stuff that is in a SCJ motor. If this car had a motor transplant years ago they swapped EVERYTHING from a SCJ car because it's all there. The Marti report lists the axle as A code 3.50.  I was just wondering if it was possible that Ford built this car this way. Some people seem to think so.
Dave
Offline svo2scj
« Reply #3 on: January 23, 2011, 02:01:52 PM »
I was just going of "probability" .  Being SO LATE I figured the the only way would have been if it was for high speed testing/tire car.    Again if you found evidence of pace car use at a track or DSO oddity keep looking.
Mark
P.S.  But please don't post a photo of a VIN if it is 165905 !!   I don't think my heart can take finding my original motor after 9 years of building a SCJ for it !!
« Reply #4 on: January 23, 2011, 03:06:18 PM »
.................. Some people seem to think so.
Get a look at the shipping invoice and or a Marti report and the discussion would be an easy one. I'm beating (though could be pleasantly surprise) that its just things that were added years ago. Have seen at least 6 other 69's done that way. Not sure what the idea of a "late car" would add to the discussion since the parts could just be used in the following year - not like they were trying to use the parts up IMHO
Offline SCJSTU
« Reply #5 on: January 29, 2011, 08:33:14 PM »
if you have a Marti showing you its a factory 3.50 rear you will have a hard time convincing folks its  a factory scj car......
1969 Shelby GT350 convertible  4spd-AC built 1-27-69
1967 Mustang S-Code 4-speed built Jan 1967 non therm
1956 Ford F100 Big Window 392 Hemi
1961 Falcon 2 Door Station Wagon 302V8
2004 Mach 1 Azure Blue
