Author Topic: 2 questions as I change my heater core  (Read 2013 times)
Offline hankmeister
« on: October 12, 2020, 01:47:39 PM »
Hey all, currently involved in one of our least fave activities.  :-\  Two questions:
1. Where the heck does the hotwire for the fan motor plug in?  It was just hanging loose in the engine bay, I believe it goes through one of the little holes in the firewall and plugs in....somewhere.
2. What the heck is this electrical thingy on the heater box? I can't even imagine what it could be for.
EDIT: 70 sportsroof with 351C, no air. Metuchen built.
Many thanks in advance!!
H
« Last Edit: October 12, 2020, 03:26:52 PM by hankmeister »
Hank
70 Fastback
351C / 4 bbl / 4 spd / front disc brakes
No a/c or p/s
Wimbledon Wht
Offline hankmeister
Re: 2 questions as I change my heater core
« Reply #1 on: October 12, 2020, 01:58:41 PM »
Here's the electrical thingy, coils inside the heater box, the prongs on the outside.
Thanks in advance
best
H
« Last Edit: October 12, 2020, 02:10:10 PM by hankmeister »
Hank
70 Fastback
No a/c or p/s
Wimbledon Wht
« Reply #2 on: October 12, 2020, 02:54:58 PM »
That is a resistor that gives you different fan speeds.
FYI it would help us to help you if you would tell us the year, model and assembly plant for your car.
Offline hankmeister
« Reply #3 on: October 12, 2020, 03:26:00 PM »
Interesting, and thank you.
Sorry, I thought my signature explained it - my fault, should've put that in the description. It's a 70 sportsroof with a 351C, built in Metuchen.
all the best
H
Hank
70 Fastback
No a/c or p/s
Wimbledon Wht
« Reply #4 on: October 12, 2020, 03:36:33 PM »
Sorry I missed it. Also some of us have more cars. LOL
« Reply #5 on: October 12, 2020, 03:45:34 PM »
Hank,
Get a set of Mustang Assembly Manuals and a Ford Shop manual for your year car. Most of what you need to know is in those documents.
Offline hankmeister
« Reply #6 on: October 12, 2020, 05:44:55 PM »
No worries! I should've put it in the title or opening sentence.  8)
Hank
Hank
70 Fastback
No a/c or p/s
Wimbledon Wht
Offline hankmeister
« Reply #7 on: October 12, 2020, 05:46:51 PM »
Hank,
Thanks Jim. I know from past experience that sometimes (often?) a wiring diagram doesn't show a realistic "location" for certain electrical components/connections. I searched around both under dash and engine bay, couldn't find an obvious connection for the blower motor. I'll get out the shop manual to see what I can find.
best
Hank
Hank
70 Fastback
No a/c or p/s
Wimbledon Wht
Offline hankmeister
« Reply #8 on: October 13, 2020, 03:55:50 PM »
Well, just in case anybody has the same dilemma as myself in the future, it seems that from the wire coming off the blower motor and thru the firewall (seen in one of my photos above) there should be a short cable between that wire (with a female receptacle) and a squarish connector that attaches to the bottom prong of the resistor. While researching online I found and ordered a repair kit from NPD.com.
best
H
Hank
70 Fastback
No a/c or p/s
Wimbledon Wht
Offline hankmeister
« Reply #9 on: November 08, 2020, 01:04:23 PM »
best
H
And lo and behold, I found the original short jumper wire tucked up against the firewall, behind the front(?) half of the heater box. Oh well.
It also seems my fan motor is not working...so I have the added pleasure of having to pull the heater core & box fully out, to install a new fan motor. Oh joy.
best
H
Hank
70 Fastback
No a/c or p/s
Wimbledon Wht
Offline DougDyar
« Reply #10 on: November 14, 2020, 12:55:32 PM »
best
H
I have a NOS Motorcraft blower motor for sale if you need one. csx4068 at gmail dot com.
Doug
0F02G203277
Offline hankmeister
« Reply #11 on: November 18, 2020, 04:00:11 PM »
Doug
Thanks Doug. Did a direct jump from battery to blower, and even tho it whined a bit (as do most of us at 50), it still worked. So for now i'll save the expense. Next step is to swap out the fan switch on the dash control, and if that doesn't work then the resistor on the heater box, I reckon.
Again tho - thank you for the offer!
Hank
Hank
70 Fastback
No a/c or p/s
Wimbledon Wht
Offline hankmeister
« Reply #12 on: July 20, 2024, 07:41:18 PM »
Old thread, but took the Mustang out today for a drive & wash. I drive the car every 3 to 5 weeks, about a 10 mile circuit (give or take) to keep it oiled up & running. As I was driving, I thought 'that smells like coolant'. Got to the car wash and saw coolant dripping from passenger side floorpan. So after only about 300-350 miles (and that's a generous guess, but I have to guess since the speedometer & odometer aren't functional) the heater core is once again leaking (badly) and has to be replaced. I've changed the coolant twice in the meantime too, so doesn't seem like that should be eating it up.  On the plus side, I never fully reinstalled the dash, due to other ongoing work.
best
Hank
Hank
70 Fastback
No a/c or p/s
Wimbledon Wht
« Reply #13 on: July 20, 2024, 08:53:23 PM »
I would check your grounds. Are you using a brass heater core?
