Author Topic: Wipers to park position  (Read 643 times)
Offline calypso
« on: October 10, 2020, 01:42:23 PM »
My wipers won't park.  I have a 2 speed motor and switch.  I want to adjust the park switch but the arms never go that far down to see if the switch is adjusted correctly.  Advice??
Re: Wipers to park position
« Reply #1 on: October 10, 2020, 02:10:26 PM »
please tell us what year you are working on. suggest you add the car info to your signature to keep from being repeatedly asked this info.
« Reply #2 on: October 10, 2020, 03:16:28 PM »
I recommend getting in the habit of looking at the forum location.  This is clearly in the 1966 area.  I was in the same boat as you until someone pointed it out.   In some cases it is not enough, but in some like this it should suffice.  John
« Reply #3 on: October 10, 2020, 03:17:41 PM »
i did. BUT if he needs additional help it cannot hurt to have that info in the sig. it is standard procedure here.
« Reply #4 on: October 10, 2020, 03:39:48 PM »
Agreed
Offline calypso
« Reply #5 on: October 10, 2020, 09:39:21 PM »
John, thanks for defending me.  If it's in the 66 heading, it seems obvious to me that it is a 66.  I have found and repaired the problem.  Thanks to you all.
« Reply #6 on: October 10, 2020, 11:29:43 PM »
To help others in the future that might have the same problem: what did you find that was the problem?
Offline calypso
« Reply #7 on: October 11, 2020, 12:20:23 AM »
The green wires and the ground to the park switch were not making good contact.
