Author Topic: Decals on 1968 Dearborn 289 coupe  (Read 1149 times)
Offline don.piotrek
  • 12/1/1967: a '68 Dearborn C-code coupe
« on: September 29, 2020, 06:23:18 AM »
Guys, I am finishing the restoration of my sunlit gold '68 coupe.
For the final touch I need the decals to be placed in the right places. As the car was already repainted pretty badly when I bought it, it missed most of the decals - so no clue where they were originally.
I know already (a bit too late) that the Jim Osborn's kit is not perfect, but is what I have
1. Safety act information - does it apply to 1968?
2. CAUTION-FAN goes centrally on the fan housing
2. FRONT - goes centrally on the front of the air cleaner, but does it apply to 1968, or more precisely - Dec 1st, 1967
3. Jacking instructions - jack
4. BATTERY OK - goes behind the battery on the fender apron, close to the starter solenoid?
5. Emissions control ?
6. Ignition coil decal - ignition coil lower part, anywhere
7. Genuine FoMoCo parts - where?
8. AUTOLITE Regulator - regulator cover
9. Tire size/ pressure - glovebox, anywhere?
10. Service/ Maintenance - I had it originally on the passenger side shock tower, should it be there, or moved to driver side?
11. Jack usage/ stowage - inner deck lid, lower right side?
12. Dealer notice - behind rear license plate
Plus:
289 CUI - goes on the air cleaner lid, front centre
I have this one, instead of rounded "Autolite spark plugs". Shall I use this one? And if yes, where?
Thank you
Offline Coralsnake
Re: Decals on 1968 Dearborn 289 coupe
« Reply #1 on: September 29, 2020, 10:14:09 AM »
1. Safety act information - does it apply to 1968? Yes bottom of decklid
2. CAUTION-FAN goes centrally on the fan housing NOT USED
2. FRONT - goes centrally on the front of the air cleaner, but does it apply to 1968, or more precisely - Dec 1st, 1967 NOT USED
3. Jacking instructions - on the jack
4. BATTERY OK - goes behind the battery on the fender apron, close to the starter solenoid? Yes
5. Emissions control ? Some cars depending on engine and build
6. Ignition coil decal - ignition coil lower part, anywhere NOT USED original ink stamped
7. Genuine FoMoCo parts - where? NOT USED
8. AUTOLITE Regulator - regulator cover NOT USED original ink stamped
9. Tire size/ pressure - glovebox, anywhere? Yes, on smooth area of liner
10. Service/ Maintenance - I had it originally on the passenger side shock tower, should it be there, or moved to driver side? Would put it back there
11. Jack usage/ stowage - inner deck lid, lower right side? Bottom of decklid
12. Dealer notice - behind rear license plate yes
Bottom decal is generic air cleaner decal, most were specific to engine air cleaner size
Pretty sure assembly manuals give specific information but looking at original cars near yours would be best source for information
About half of what you have is not consistent with production
« Last Edit: September 29, 2020, 10:24:18 AM by Coralsnake »
« Reply #2 on: September 29, 2020, 03:56:10 PM »
As mentioned many times on this forum - don't buy a "kit". It includes too many decals that are not meant for your car and often they are (if right for your car) not the best quality ones out there.
Pete gave good responses but to help out maybe a little more. When was your car built? I found it over to the left - 12/1/1967
From what you have posted I would guess that you have a 68 coupe with a C code and automatic. Correct?
« Last Edit: September 29, 2020, 10:10:49 PM by J_Speegle »
« Reply #3 on: September 29, 2020, 10:55:43 PM »
For the Service/ Maintenance decal here are some examples from the same production period as your car plus or minus two weeks
Trunk lid for locations of your two trunk decal
Engine compartment
Yellow - Battery inspection. Will need to be filled out.
Purple - Another service sticker location
Red - Cubic inch decal
Light green - Air filter replacement
Light blue - Emission sticker
Yellow - Engine ID sticker
Offline No Paint
« Reply #4 on: October 07, 2020, 11:47:32 PM »
Here are the service sticker placement measurements from my 1/25/68 Dearborn 289 coupe. Measurements are to the center of bend radius
C 2 1 Coupe, 1/25/68, Dearborn, No Paint Code, TS Hood, Bumper Guards, Manual Brakes / Steering, Originally January Dealer Promotional Black Hills Gold Paint.
Offline don.piotrek
« Reply #5 on: October 14, 2020, 05:29:13 AM »
So how do I tell if I need the emissions sticker?
The car is
  • built at Dearborn, Dec 1st, 1967 (5 days ahead of schedule)
  • c-code, C4 automatic transmission
  • Fargo DSO 42
  • no additional mechanical options listed in the Marti Report
Thanks.
« Reply #6 on: October 14, 2020, 02:40:58 PM »
If the car was built and sold to the public. Think even exports optioned as your car had them but that does not appear to apply
Offline don.piotrek
« Reply #7 on: October 15, 2020, 07:32:49 AM »
Thanks Jeff.
By the way - why would you consider my car 'exports optioned'?
« Reply #8 on: October 15, 2020, 03:00:49 PM »
Would not but when answering question on the forum you have to consider what might be going through other readers minds so that they do not lump together different things or make leaps in their assumptions. Didn't want to say "all" without throwing out the possibility of some unusual situation I'm not aware of coming around the turn.   :)
Think of it in this context - a side comment.
