Author Topic: Fuel Line Hose at Carb  (Read 1105 times)
Offline 1970 Snake
« on: September 25, 2020, 08:36:21 PM »
Can anyone advise where to buy the correct 5/16" hose and crimp clamps for the fuel pump line to carb filter connection at the carb for a 1970 mustang 428CJ
Dearborn Built Sept 4, 1969
1970 Mach1 428 CJ R-Code C6
dash tach, front bumperettes
Re: Fuel Line Hose at Carb
« Reply #1 on: September 26, 2020, 12:03:10 AM »
If after looking you can't find any I have the correct looking 5/16 crimp clamps without the dimple like all the modern crimp clamps have. PM me.
Offline 69GT350H
« Reply #2 on: September 26, 2020, 12:43:15 AM »
Offline 69GT350H
« Reply #3 on: September 26, 2020, 01:06:26 PM »
I'd call and verify what was said.
 Verified Buyer
Great product but NPD needs to put a better description for it, the kit comes with the 5/16 hose and clamps for connecting the carb to the fuel pump line bit says nothing about it at all.
Submited on July 23, 2019 by Steve C.
Offline 1970 Snake
« Reply #4 on: October 21, 2020, 08:57:11 AM »
Sorry for the late response, the NPD hose kit indicates it is 3/8" hose and not 5/16". I have the correct 3/8" hose which is used on the line coming from the gas tank and now have the correct 5/16" crimp clamps from DNO. Are you saying the NPD hose is 5/16" ID and not 3/8" ID as indicated in their description??
Offline cobrajet_carl
« Reply #5 on: October 21, 2020, 04:41:09 PM »
It's a Marti part, you could call them.
https://www.martiauto.com/itemselection.cfm?item=FK-2C&selecteditem=yes
Carl
70 and 71 Dearborn mach Is
Offline 1970 Snake
« Reply #6 on: October 24, 2020, 01:09:31 PM »
I just found my original factory hoses, fender apron to fuel pump and fuel pump tube to carb. The hoses and clips are as per the Marti offering, particularly the clips on the carb hose, they are the same as Marti's.
What is puzzling me is why all I have read, indicate or show the crimp clips at that location, yet my originals are NOT crimp clips. I stand corrected, the original piece I found was the fuel line to fuel tank, hose and clips.
« Last Edit: November 08, 2020, 06:47:47 PM by 1970 Snake »
