Author Topic: Lower Control Arm Eccentric Caster Camber Adjustment Bolt  (Read 662 times)
Offline truetriplex
« on: September 24, 2020, 02:42:58 PM »
For a 69 428 Mustang, on the Lower Control Arm Eccentric Caster Camber Adjustment Bolt, what plating or finish did it have on it?
Re: Lower Control Arm Eccentric Caster Camber Adjustment Bolt
« Reply #1 on: September 24, 2020, 06:59:42 PM »
Have always looked darker than bare steel in person to me. Most likely darkened from being harder metal or phosphated. How ever you choose to get to the right look
Original
« Last Edit: September 24, 2020, 07:44:33 PM by J_Speegle »
« Reply #2 on: September 24, 2020, 07:40:10 PM »
Have always looked darker than bare steel. Most likely darkened from being harder metal or phosphated. How ever you choose to get to the right look
Original
+1 bare steel originally .Restorers many times do a light phosphate which doesn't darken too much but will better resist rust when used along with one of the anti rust products like boe shield.
